Mani 4 '75 olds rocket 350?
Old May 3, 2007 | 11:36 AM
sacramento's Avatar
I have an bad leak on headers and heard stock manifold is the way to go but can't find one yet. Anybody have a good set or idea?
Old May 3, 2007 | 05:18 PM
Is the problem that the headers are rusted or just that the gasket is bad? If the latter, spend $30 and get a set of copper header gaskets (and spend a little more and get copper collector gaskets also). If you go to manifolds, you will need to replace your head pipes as well.
Old May 4, 2007 | 08:14 AM
sacramento's Avatar
'75 rocket exhaust manifold
The headers I had were likely warped, couldn't get a good seal even with, good gaskets. I now have a new long block, and am trying to figure out best way to go. A friend said headers tend to have leaking problems (particularliy with the olds.) Its just hard to find a set of good e-manis, and I don't think they make reproductions on that model year. what do you think?
Old May 4, 2007 | 01:19 PM
People say a lot of things. I've had headers on several Olds motors that worked fine and did not leak. I'm not aware of any repro small block exhaust manifolds.
Old May 7, 2007 | 11:33 AM
sacramento's Avatar
Headers or Mai?
Yeah, I'm no expert in the olds engines, but I do knoe that people like yourself use them all day long, so they can't be that bad. Its looking like I'll be doing the same. Someone suggested that I tighten them acouple of times a year (as opposed to reg exhaust) and that should be more than enough. Thanks for the reply!
moys71
Feb 16, 2021 08:22 PM
Eddie Hansen
Dec 15, 2014 06:26 PM
85cutlass6.6
Jan 28, 2012 10:49 AM
jackalack
Mar 25, 2009 12:43 PM
sacramento
Jul 28, 2007 07:03 PM
