Looking for a replacement radiator
Old Aug 30, 2025 | 02:13 AM
hirngespenst's Avatar
Hello everyone,
After fixing a few leaks in the system, now all that's left to do is the radiator.
I removed it and noticed that it had already been soldered in a few places. I would therefore like to replace it with something new.
Can you tell me where to get one? Can I get something like this anywhere?
The part number is: 3002346-R146
When I search for it, I only find two threads here in the forum that mention manufacturers that I can't clearly find on the internet. I assume it will only be available from American parts dealers, right? I'm not familiar with the US, so I would appreciate it if you could recommend one or two such dealers.
One person mentions “Hairyolds,” but Google Germany finds lots of cool cars, but no dealers.
Thanks and best regards from Berlin
Old Aug 30, 2025 | 02:30 AM
illumined's Avatar
1978 Ninety Eight
If you want an exact replacement you can go with US Radiator. It's not cheap but it's worked well for me. I ended up upgrading mine to the heavy duty version so it's even better than the original.
Old Aug 30, 2025 | 03:07 AM
Since you're overseas, is there a shop anywhere in Germany that could repair the radiator you currently have? Even in the US it's a dieing service, but it might be worth investigating.
Old Aug 30, 2025 | 03:10 AM
Tri-Carb's Avatar
The exact Harrison radiators are no longer made. The best lookalike copper radiators are likely made by the US radiator company: US Radiator - US Radiator.
A second option is to find a good core here and have it rebuilt.
Old Aug 30, 2025 | 01:44 PM
FStanley's Avatar
I had my local radiator guy save the tanks and put a new high efficientcy copper one one. knocked off 15F degres runs right at thermostat temp no matter outside tempa.
Old Aug 30, 2025 | 01:49 PM
2blu442's Avatar
I'm assuming this is for your 1965 Vista Cruiser, correct? You might do a search for a 1965 442 or Cutlass with the V8 engine radiator. That should fit in your car core support. John
Old Aug 31, 2025 | 04:22 AM
Dynoking's Avatar
https://usradiator.com/product/oldsm...t5KTs94NGJ5E-F
https://www.radiatorexpress.com/prod...C7a4S6ZF9ZaPbU
Tancuda
Jun 10, 2024 02:38 AM
Frisbee_k9
Mar 6, 2023 05:01 PM
DR_DAN
Dec 15, 2022 08:07 PM
Mr Shifty Sidney
Jan 6, 2016 04:19 PM
