Looking for information on 76 350 motor?
I just recently brought a 350 motor and trans. I looking to put some good work into them for the street. I have a 85 Cutlass right now. I need to know what would anyone recommend I put into the entire motor, & trans to be street legal, but still have alot of horses. Also would I have to change my rearend? The numbers on the motor is 395558 2 16, Trans #s r 70 JS179 D, Rear End #s r 9AJ 0 170 or 176 10 Bolt. Anyone with input please give me some part numbers, especially for the motor starting from the block to the carb.
Please, help me build my car. I'm new to this site and I'm really not a machanic, but I know how to change oil and minor machanic work like changing a fan belt,starter and things like that. As far as inside the motor, I'm green. All I really know is I have a 350 motor and I'm not so sure about the trannie. My prior post were from all the number & letters I got off the motor and trannie. Thanks for all replys.
The first question is, what do you mean by "street legal"? Is your 85 required to pass emissions testing where you live? If so, that will limit what you can do.
Yes it is.
I live in Louisiana and right now, I have a 3.3 in it. I just want a to bore it over .30, Good Cam to make it sound good put positive traction and fast. Thanks for any info. I'm not to familiar about the inside of the motor, so I would need names and part # Please of good reliable olds parts.
Finding a good machine shop is the first order of business. With your location posted now hopfully someone on the site will recomend one to you. A good shop will discuss the options with you to give you the best bang for your buck. Others on this site who have built 350's can chime in with recommendations that you can use when you discuss the build. Good luck with the build
Tedd Thompson
March 27th, 2012 08:44 PM
my442w30
November 24th, 2011 04:37 PM
1964droptop
August 29th, 2009 06:49 PM
warrior71
Hurst/Olds
April 7th, 2009 09:03 AM
POKANOKET
July 14th, 2007 02:58 PM
