Looking for 4bbl intake
Old Apr 12, 2022 | 08:53 PM
jaylen's Avatar
Need to buy a 350 4bbl intake that fits a 1969 ASAP
In the Virginia - North Carolina area
Old Apr 12, 2022 | 09:07 PM
You might want to be a bit more specific in what you're trying to accomplish. Stock cast iron or aftermarket aluminum.
Old Apr 13, 2022 | 05:12 AM
If you need the correct 1969 intake, that's casting number 398663, used on every 1968-69 350 with 4bbl. This intake uses a divorced choke with a pocket in the crossover and is different from casting 390327 used on the 1966-67 4bbl motors.
Old Apr 13, 2022 | 09:38 AM
jaylen's Avatar
get specific of what? Because i don’t care if it’s cast iron or aluminum
Old Apr 13, 2022 | 09:41 AM
jaylen's Avatar
I’m trying to throw something on a 69 350. Doesn’t matter. Where are you located ? I’ll pick up if you got anything and near by
Old Apr 13, 2022 | 09:53 AM
See, this is why the question was asked. Your first post can be read as looking for a specific 1969 manifold. If all you care about is any small block Olds 4bbl, it would have helped to know that. The mind reading thing still isn't working. You'll find a lot of SBO intakes for sale.
Old Apr 13, 2022 | 03:17 PM
You see how easy that was... In that case any SBO intake will work and they should be plentiful.
Old Apr 14, 2022 | 04:26 AM
BillK's Avatar
https://www.summitracing.com/parts/edl-2711
Summit is normally 2 days to Va
Old Apr 14, 2022 | 10:17 AM
rickw30's Avatar
I may have a single plane Holley Street Dominator if you want. $175 +ship from Florida.
Lebb662
May 17, 2019 01:59 AM
cheven
Jun 4, 2018 06:10 AM
dnmfranco
Oct 21, 2013 08:25 AM
1966g10
Sep 15, 2013 08:12 AM
krooser
Feb 4, 2013 07:37 AM
