lifters recomendation
Old Aug 9, 2015 | 07:29 PM
Macadoo's Avatar
As some of you already know, I've had a sticky lifter ever since I buttoned up my motor. The GM EOS oil supplement added at oil change seems to do the trick but since getting back from NY I noticed a small oil leak at the front of the intake. MAW pull the intake and replace the lifters.
Any recommendations for lifters for my 350? CutlassEFI ground the cam, it has a little less than .5" lift, if that matters. Should I just go with some cheap Sealed Power stock lifters or spend the extra at Comp Cams?
Old Aug 9, 2015 | 07:41 PM
Sometimes they get dirt in them and once its evacuated they are fine. If they are not making noise, your good to go.
Old Aug 9, 2015 | 08:11 PM
Macadoo's Avatar
I've had trouble with this one lifter ever since first-fire. If I don't use the EOS, it doesn't just tick, it clacks
Funny thing is, I can cruise town all day without an issue. But if I hit the interstate (or even route 66) without the EOS, it's clackity-clack.
Old Aug 9, 2015 | 08:13 PM
Macadoo's Avatar
I should also mention that I swapped in the comp cams roller tips and did a running adjustment on all preloads. Somewhere between a half and 3/4 turn.
Old Aug 10, 2015 | 02:38 PM
Macadoo's Avatar
Any opinions?
Old Aug 10, 2015 | 03:56 PM
If they are still giving you issues then by all means take them apart and clean them or replace.
Old Aug 10, 2015 | 04:14 PM
cutlassefi's Avatar
I'll ship you a set of Morel/PBM lifters for $70.00.
Old Aug 10, 2015 | 04:23 PM
There you go Mac, cheaper than the stockers at the parts store.
Old Aug 10, 2015 | 04:57 PM
RandyS's Avatar
Mac, just curious, did you install new lifters when you put in the new cam?
Old Aug 11, 2015 | 04:46 PM
Macadoo's Avatar
With all respect, Mark, would these be different than the ones you sent me with the cam? Just don't want a repeat problem. And can I be sure it is, in fact, a lifter problem and not something with the bore? As I said, I can drive around town all day, 190* engine temp, without a single tick. Ten minutes on the interstate, 65-70 mph, 190* engine temps, and it clacks profusely until it settles down. I'll trust your experience here.
Randy, as noted above, yes. All new lifters.
Old Aug 12, 2015 | 05:16 PM
cutlassefi's Avatar
Yes same ones. You could have an oiling issue.
Old Aug 12, 2015 | 06:33 PM
76olds's Avatar
Hookers under Hood
Hey Mac, I hope a new set of lifters will quieten things down. I know you put many hours into doing a great job on your engine, engine bay etc. I really hope its just a bad lifter or a little debris under that specific lifter.
I don't know much about oiling issues, however the statement " oiling issues" sounds like a huge issue.
I hope you things work out with a new set of lifters.
Eric
Old Aug 13, 2015 | 02:25 PM
Macadoo's Avatar
I think there's about an 80% probability that it's a lifter and not a circulation issue. When I opened the motor up, the lifter valley was very clean and the lifters were tight but came right out. Plus, the motor didn't tick before the refresh.
@ Mark, I don't suppose my current lifters are under warranty. It's been a little more than 2 years (since purchase) and about 3k miles. Can I just replace two or three of them in that area? It sounds like cylinder #1 but it could be #3 or [less likely] #4.
Old Aug 13, 2015 | 03:53 PM
cutlassefi's Avatar
No they're not but I'm sure we can get you two lifters for n/c.
Old Aug 13, 2015 | 04:26 PM
Macadoo's Avatar
I don't mind paying for a couple but I can't argue free-of-charge
Thanks Mark, I'll PM you.
62 Cutlass Convert
Dec 18, 2014 04:42 PM
RAMBOW
Mar 7, 2011 03:18 PM
dsolomon
Mar 1, 2011 06:50 PM
panos
16
Apr 29, 2010 12:49 PM
RAMBOW
May 21, 2009 12:08 PM
