Intake Manifold - Edelbrock 3711
Hey Guys,
Need some help. I'm replacing my stock 350 Rocket intake manifold with an Edelbrock Performer #3711 for my 70' Cutlass Supreme. It's a hot air choke, non-EGR application and I'm questioning the transition of fittings and sensors from old to new.
The port locations from the old to new do not match with the exception of the thermal vacuum switch and the temperature sensor. I have several brass 90 degree fittings that I pulled off the stock manifold that have no matching place on the new. Also the thread sizes don't fit, the stock ones are too small. Did Edelbrock simplify things and I don't need as many vacuum lines as I did before?
Lastly, there is a 1/2" port I don't have anything for so do I just plug it with a pipe plug? Same with a couple of small miscellaneous items, can I pipe plug those too?
Threads should be the same so maybe the old fittings are damaged or corroded. Manifold vacuum can come from any port, just figure out what you need with the new set-up plus you can use tees on the vacuum hoses if needed. Pipe plugs work on unused ports. On the choke, consider a block off plate and convert the carb to electric choke. I'm assuming factory correctness not highly important since you are not using the stock manifold.
1) Any coolant sensor must be in flowing coolant. That means the bungs in the water crossover on either side of the t-stat housing. Don't put a coolant sensor (or TVS, or similar device) in the bungs at the rear of the intake.
2) Any manifold vacuum port can go into a bung on any intake runner.
3) Any unused ports can be plugged with pipe plugs
4) Use bushings where the holes in the manifolds are larger than the fittings. You can get bushings in the plumping dept of any hardware or home improvement store. You may find that it's much cleaner to simply buy new fittings at an auto parts store with the correct thread, however.
Same issue
So I'm having the exact same issue. Except the new parts that go on the front and rear passenger side. The 1/2 plugs. That one plugs into the wire harness that has 3 ports and the back one that has the one. I don't know what either of those are called. When you get this complete, will you send updated pics and tell me what those parts are called? That way I know what to do. It would be greatly appreciated. I'm no mechanic and I could use all the help I can get. Thanks
This is an old thread so not sure if the mods will relocate this but I’ll help how I can. The port in the front is for the thermo vacuum switch which has ported vacuum lines and connects between the TCS solenoid and the manifold. I deleted this along with the solenoid and run the corresponding trans vacuum line directly to manifold vacuum. If you’re wanting to keep stock look and functionality, you should be able to find one used somewhat easily. For mine, I plugged that port as it’s not needed. For the port in the rear, that’s for the heater control valve. There’s a heater hose connected to it on one side and a vacuum line on the other. These can also be found new or used. Pics attached for reference.
thechomp89
November 27th, 2009 09:35 AM
