Intake and carb swap
Ok so I have a 1972 cutlass base 350.
Currently a 2 barrel and its warped.
Here's the questions.
I bought a 4 bbl edelbrock performer rpm, and a 1405 edelbrock carburetor.
What will I be needing, if anything to complete the swap, or did I buy the wrong parts.
Please let me know if anyone has done this swap or knows of doing it.
Hi. Others will chime in with more specifics, but you'll definitely be needed a different fuel line from pump to Edelbrock carb. I've seen the braided type fuel line work well with this combo. Oh, and the throttle cable bracket will be different. Not sure, but it might already be included in your carb kit.
They were bought off eBay �� so not much I can do u til they get here, I planned on camming my motor which I did research and they said it would be fine to run the intake an carb, but a cam is definitely needed for better performance, I got the parts cheap, and I'm not sure if the carb has the bracket or not, I got the carb for 185 near perfect and the intake for 268, can't complain I guess on the price
Pick up a tuning kit for that carb. I would talk to Cutlassefi, he has custom cams for low compression Olds V8's. I am sure your 350 is in desperate need of a timing chain anyways.
Lol well I got my intake in, and its definitely tall enough that I shouldn't have any problems with the throttle linkage, and yeah I need a cover u til I fix my rear window seal, its cracked and letting in water
TIM FISKUS
May 12th, 2013 05:17 AM
svnt442
July 17th, 2011 04:43 PM
