Initial startup, 67’ 330, help
Old Apr 30, 2022 | 05:29 AM
Kirdid's Avatar
Hi!
i’ve rebuilt a 330 10.5:1 comp and i am struggling with getting it started.
i’ve given it a slight bit more than 10° of initial timing on the crank at the compression stroke.
dropped in the distributor(HEI) and lined it up with #1 cyl and checked spark by grounding the #1 spark plug and wiggling the distributor then pulled it back slightly.
carb is a 600cfm Edelbrock, it has fuel, spark when grounded outside the cylinder and i am able to achieve some small sputters but not much more. It feels like it cranks a little too slow for some reason as well. Any thoughts are apreciated.
Old Apr 30, 2022 | 06:36 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Get someone to crank over the motor or hook up a remote starter and trying turning the distributor at the same time. Did you fill the carb bowl with gas? What starter is in it? Is the battery fully charged?
Old Apr 30, 2022 | 07:06 AM
And you're SURE you don't have the distributor 180 deg out?
As for timing, you can use a timing light when the engine is cranking on the starter. I usually leave the distributor a little loose on initial startup and have to turn it slightly while cranking.
As noted, be sure the carb float bowl is filled. Be sure you battery is fully charged, wire connections all clean and bright, starter in good shape, etc.
Old Apr 30, 2022 | 07:53 AM
Kirdid's Avatar
poured a good chunk of gas into the carb, it was a new starter when i started the project so it has only been used to crank the engine so far. And yes the battery has been topped of at the start of each session
Old Apr 30, 2022 | 07:56 AM
Kirdid's Avatar
i am 100% sure as i have tried it both ways to make sure i wasn’t going insane. I will try again once the battery is topped off with a full bowl of fuel, and a timing light while trying to wiggle the distributor.
Old Apr 30, 2022 | 08:32 AM
Advance the timing a bit more, 10* with an HEI won't work.
Old Apr 30, 2022 | 08:50 AM
Kirdid's Avatar
thank you, i will give it a shot! 15°?
Old Apr 30, 2022 | 08:56 AM
15-20*, you won't hurt the engine with no load on it. Do you have a full 12v on the HEI, in other words, not using the resistance wire?
Old Apr 30, 2022 | 09:15 AM
Kirdid's Avatar
I’ll try close to 20° and yes the wires have ≈0 meassured resistance
Old Apr 30, 2022 | 09:43 AM
I found the easiest way to verify TDC on the compression stroke is stuff a something such as a wine cork in the #1 spark plug hole and turn the engine until the cork pops out. There's no uncertainty with this method.
Old Apr 30, 2022 | 09:47 AM
Kirdid's Avatar
yes, i always use my thumb, them i know the side with the most whistling is the compression stroke
brianbeez67
Jan 16, 2021 11:20 AM
brianbeez67
Mar 13, 2020 11:42 AM
Roger60
May 15, 2018 03:13 AM
blaker1
Dec 5, 2011 06:36 AM
gearheads78
May 8, 2008 07:27 AM
