Identifying High Compression 330
Old May 7, 2012 | 07:45 AM
jvock6's Avatar
So the engine is now out and off to the machine shop. However I noticed that the pistons in the engine are high compression. Is there a way to determine if the engine was built as a high compression engine? I think it would be pretty neat to have one built that way, but I want to find out before I go around saying anything. For all I know some one could have changed out the pistons. Also what were the decals for the ultra high compression sticker placed on during what years?
Thanks for all the help! As soon as the engine is back in Ill post a thread of the rebuild!
Old May 7, 2012 | 08:13 AM
L69's Avatar
L69
Passenger side head pad should end with a G after the engine number. Obviously pistons are a sign as well as a Red air cleaner but most of these things can be added. The G on the head is your best bet, if you still have the heads.
Old May 7, 2012 | 09:21 AM
jvock6's Avatar
In the stamping I believe it's a U I can't check at the moment since they are in the shop. Do you happen to know what the U is for?
Old May 7, 2012 | 09:30 AM
L69's Avatar
L69
check this out. this is for a 67 go to around page 5 has all the codes. http://wildaboutcarsonline.com/membe..._Section_0.pdf
U I have not seen unless you are confusing it with a V and that would be a 442 head but I highly doubt that, considering you have a 330.
Engine # should start with a W ###### and end with a G if its a Hi Comp motor. All this will be on the front pad on the passenger side head just behind the alternator.
Old May 7, 2012 | 09:37 AM
L69's Avatar
L69
What year is you motor. 64-65 letter will start with a T and 66-67 will start with W. For some reason I thought you had a 66. Either way good luck
Old May 7, 2012 | 11:14 AM
jvock6's Avatar
We'll I saw that some one had written 1965 on the fire wall so I think that it maybe be a 65? I know its not a 67 even tho that;s the car that I have.
MudEye
Jun 2, 2015 10:45 AM
kanner1
Oct 8, 2011 05:31 PM
Ficks
Mar 25, 2011 06:43 PM
tlucas07
Mar 23, 2009 11:40 AM
