Hypertech Chips
Old Apr 16, 2013 | 07:06 PM
1BOSS83's Avatar
Hypertech Chips
Anybody ever add one of these to a 80s Hurst or 442? Do they do anything besides richen your mix and advance your timing?
Old Apr 16, 2013 | 07:19 PM
DoubleV's Avatar
The general concensus is they're a waste of money. Never used one myself though.
Old Apr 16, 2013 | 08:53 PM
Rickman48's Avatar
Some guys swear by them, others swear at them!
I used a Edelbrock product, [no longer made] on a 86 GP 2+2 w/305 Chev, andwas super satisfied.
Hypertech was supposed to be better.
Old Apr 17, 2013 | 07:36 AM
The CCC system on the 307 has a VERY limited range of adjustability. All it controls that affects engine performance is the primary side mixture ratio and the advance curve. Any aftermarket chip can only play with these two variables and if it's C.A.R.B. certified, it can't make much difference in either from stock settings.
I'm sure that if you spend $200 or $300 on a chip, the "butt dyno" will tell you that there's been a significant increase in performance. Quarter mile times would argue otherwise, however.
The secondary side of the carb is purely mechanical and responds to metering rod changes and adjustment of the secondary air door warp spring, just like on any Q-jet. Also note that on the 307 carb, the secondary air doors are limited to only about 70 degrees of opening. You can file the tab to get them open the full 90 degrees, though it isn't clear that an otherwise stock 307 can use the extra airflow.
Old Apr 17, 2013 | 07:43 AM
1BOSS83's Avatar
Thanks Joe. Just for reference does CCC= computer controlled carb?
Old Apr 17, 2013 | 08:03 AM
Actually, it's Computer Command Control.
This link has some good information:
Understanding The ECM & System
rocketraider
Jun 11, 2015 04:01 AM
mefirst72
Feb 3, 2015 05:46 AM
auto_editor
Brakes/Hydraulic Systems
Apr 29, 2011 08:37 AM
