How to remove a Power Steering Pump Pulley?
Old May 5, 2014 | 07:42 PM
tommyd's Avatar
Hello all. I have a 1967 Cutlass and I'm attempting to remove the power steering pump pulley from the bracket to clean and paint. I can not remove the nut keeping the pulley attached to the pump. I bought a pulley remover only to find the pulley does not have a flange for the remover to attach to. Bracket and pump is already removed from the engine. I am lost! Please see picture. Any help would be Greatly appreciated. Thank you.
Old May 5, 2014 | 07:53 PM
66400's Avatar
No puller required, once the nut is off grip the pulley with your hands and just kind of tug on it till it pulls off. I like to break the nut loose while it's still on the car.
In your case if you lock a large pair of visegrips onto center flange you may be able to hold the pulley still while you break the nut loose. Impact wrench could be useful now.
Henry
Old May 5, 2014 | 08:01 PM
Grab pulley with something rubbery (the last time I did it, I held it against a railroad tie with the sole of my boot and used an air wrench. You could also contrive to wrap a fan belt around it and secure it somehow). Once the nut is off, teh pulley should come off with a sharp rap.
Old May 5, 2014 | 08:06 PM
This is what I used for mine..its a special tool - vise grip chain lock
Old May 5, 2014 | 09:48 PM
4speed455's Avatar
Take off the nut. Hold the pulley with both hands a foot off the ground. Have someone else hit the shaft with a hammer the pump will fall off.
tommyd's Avatar
Thanks everyone. So its just a "muscle" thing.
Old May 5, 2014 | 09:50 PM
tommyd's Avatar
Thanks Allen. Ill look for one.
Old May 6, 2014 | 06:46 AM
ROCKET VAPOR's Avatar
Lance
How about a non-marring strap wrench to hold the pulley.
https://www.ridgid.com/us/en/strap-wrenches
Old May 6, 2014 | 10:46 AM
The pulley remover is only for newer PS pumps with pressed-on pulleys. Return it.
Old Oct 2, 2017 | 06:12 PM
olds88royalvert's Avatar
1970 Delta 88 Royale Conv
Which way does the nut turn to loosen? The normal counter clock wise? I am down to just this replacing it on my '70 delta 88. I am going to have to hold on to it as I am sure it is "stuck" on there, just want to make sure i turn it the right way to get it off before I shove a bunch of muscle into it. My pully has holes in it too. Advice is helpful, going to do this tomorrow evening after work. Then it can all go back together.
Old Oct 3, 2017 | 06:38 AM
edzolz's Avatar
Standard thread, righty tighty...lefty loosy.
Old Oct 3, 2017 | 06:49 PM
I can’t seem to find a 7/8 wrench to fit under the nut. They are too wide and don’t allow enough “bite” on the but itself to even get some muscle or other force behind it.
Old Oct 3, 2023 | 02:24 PM
Bradjac's Avatar
70delta88 royal
wow, mine doesn't have that extra piece on the inner pulley where the shaft goes through and has to ruin it with a 3 jaw puller!
carl 87 cutlass
Nov 1, 2012 05:42 PM
1971viking
Feb 27, 2011 07:56 AM
1971viking
Feb 24, 2011 07:54 PM
MDchanic
Nov 19, 2010 02:54 AM
mcutlass1969
Mar 26, 2007 07:09 AM
