How much lift???
Old Jul 20, 2010 | 09:43 PM
76Supreme350's Avatar
How much lift???
How much lift can i get out of my motor before the valve clearance is compromised. Im going to be using the larger valves on a set of 70 cutlass heads. I have a 76 350 with stock pistons and everything. Im going to be using a street edelbrock cam with 1.6 roller rockers. should I be worried at all? I think in total the lifts will be right around .500. Thanks
Old Jul 20, 2010 | 10:34 PM
svnt442's Avatar
.500 is for stock rocker arms. With the roller rockers you're good in that respect, but you'll need to make sure you have the correct springs and pushrods and you'll be good to go.
Old Jul 21, 2010 | 10:28 AM
cutlassefi's Avatar
I did a 350 with stock #7 heads and roller rockers with lift around .550, no issues whatsoever.
Which Edelbrock cam are you going to use?
Old Jul 21, 2010 | 01:30 PM
Edelbrock 3712 Camshaft and Lifter Package
Duration @.50: I-204/E-214
Lift I-.448/E-.472 (.472/.503 w/ 1.6 Rockers)
Old Jul 21, 2010 | 02:30 PM
cutlassefi's Avatar
You won't have any issue at all. What gear?
That cam will have decent street manners but it's a bit lazy. Are the heads going to be milled at all?
Old Jul 21, 2010 | 07:07 PM
svnt442's Avatar
What in the world makes you think the specs are not with 1.6 rockers? This is advertised with the stock ratio which just so happens to be 1.6 so the advertised lift at the valve is correct as stated at .448 intake and .472 exhaust.
Old Jul 21, 2010 | 07:20 PM
cutlassefi's Avatar
X2, those cams are always configured for the application. They all use the same profile just different rocker ratios.
That's a very mild cam, not sure what you're looking for.
Old Jul 21, 2010 | 11:06 PM
I was told stock was 1.5
Old Jul 22, 2010 | 05:36 PM
svnt442's Avatar
On a Chevy, but not an Olds.
gabes455olds
16
Apr 14, 2014 04:25 PM
molasses4masses
Jan 13, 2014 10:04 AM
oldzy
Jun 30, 2011 08:40 PM
jensenracing77
May 1, 2009 02:35 PM
projectheaven
Jul 22, 2008 07:54 PM
