How to make car sound louder/meaner
Old Mar 6, 2011 | 04:24 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
1972 cutlass with rebuild engine
-mild cam
-work done on heads
-has cats with magnaflow mufflers
-4 barrel carb
-hooker headers
-olds 350
Going to get pypes exhaust and dump the cats
Old Mar 6, 2011 | 04:44 PM
MHENDERSON's Avatar
Headers.................
Old Mar 6, 2011 | 04:56 PM
firefrost gold's Avatar
Raise compretion, big cam, cut outs , like the sound of a w-30 or 31 cam.
Old Mar 6, 2011 | 07:11 PM
yes it also has hooker headers
Old Mar 6, 2011 | 07:40 PM
svnt442's Avatar
OK....why the hell does it have cats on it? I'll never understand that.
Old Mar 6, 2011 | 08:07 PM
Really hate explaining to people every time but here it is. When I bought the car the person had put them on because where I live you have something called air care to pass then you get your plates. Also after I pass aircare I will be dumping them and putting on pypes violators exhaust with an x pipe.
Old Mar 6, 2011 | 09:32 PM
oldzy's Avatar
You wanna sound louder/meaner... open headers. LOL.
Old Mar 6, 2011 | 09:39 PM
oldzy's Avatar
You want like this?... http://www.youtube.com/watch?v=uBoEjuyzp9A
Old Mar 6, 2011 | 10:06 PM
yeah I have seen his car its sick but I want something like this
http://www.youtube.com/watch?v=P_K35KYaw1c (I like this one)
http://www.youtube.com/watch?v=-D4av...eature=related
http://www.youtube.com/watch?v=spGZm...eature=related
http://www.youtube.com/watch?v=PvabQnc3hgg (chevelle)
Old Mar 6, 2011 | 10:23 PM
this is what mine sounds like
http://www.youtube.com/watch?v=p_Pj7YHKrwU
Old Mar 7, 2011 | 03:16 AM
Bluevista's Avatar
Registered
Pull a couple of plug wires and it will sound like you have a really hairy cam at idle.
Old Mar 7, 2011 | 04:02 AM
snarl softly and carry a big stick! Now were did I hear this
Old Mar 7, 2011 | 05:04 AM
cutlassefi's Avatar
What gear is in it? If you have the original 72 compression ratio it will tough but you I can grind you a small cam on a tight lobe sep, that'll keep your throttle response but give some tone. anyway you go you'll need to be careful you don't lose any low end and are able to still pass your air care.
Old Mar 7, 2011 | 07:28 AM
panos's Avatar
Homemade 3" right out the side http://www.youtube.com/watch?v=AVIQk...eature=related
I have a 2.5" Magnaflow system by now because it wasnt even possible to talk in the car while driving and is much nicer imo,(im getting old too )
Old Mar 7, 2011 | 08:03 AM
Thanks after I pass air care my plan is so put on pypes 2.5 with x pipe. Also the person that rebuild the engine told me the compression is higher then stock by a little like 8.5:1 I think. Many stock engine sound like those clips mine dosen't
Old Mar 7, 2011 | 08:09 AM
alek72us's Avatar
Olds Dreamer
Take your cats out then compare it to those clips. probably night and day differance.
Old Mar 7, 2011 | 09:05 AM
dc2x4drvr's Avatar
Spin Tech mufflers
Old Mar 7, 2011 | 09:06 AM
cutlassefi's Avatar
True but he may still need help to achieve his goal.
Old Mar 7, 2011 | 09:25 AM
alek72us's Avatar
Olds Dreamer
I'm not interfering with his goals. sorry if i made it sound like that.
Old Mar 7, 2011 | 10:45 AM
Yes after the cats are taken off and adding the pypes mufflers and x pipe it should make a differeance.
Old Mar 7, 2011 | 12:08 PM
svnt442's Avatar
Where do you live?
Old Mar 7, 2011 | 02:53 PM
Warhead's Avatar
Your videos show why you should not drive that thing in winter around a curve! Anyone with less maturity would wrap that around a pole.
Sweet, and a 65, too.
Lookin good
Jim
Old Mar 7, 2011 | 03:03 PM
ELY442's Avatar
My 70 Cutlass has 2 1/2" straight pipes with Flowmasters. I dont have tailpipes. I just have a small pipe with a slight bend after the Flowmasters. We call them duck tails. Its very loud and i set off neighbors car alarms.
Old Mar 7, 2011 | 07:10 PM
any more idea's ?
Old Mar 7, 2011 | 07:12 PM
Originally Posted by svnt442
Where do you live?
Vancouver, B.C
Old Mar 7, 2011 | 08:10 PM
oldzzy's Avatar
wait.... what....
Spin Tech mufflers
What he said!
Old Mar 7, 2011 | 10:46 PM
svnt442's Avatar
Ok I just did a little looking and I found this. http://www.aircare.ca/ap-aircareworks.php There is NOTHING that says you should install cats on a car that didn't come with them from the factory. What you should do is fix the issue that is causing the car to over pollute in the first place.
15 years ago my friend had a 72 Cutlass that was a GROSS polluter by any standards. He was allowed 800 ppm HC and was blowing well over 2000. We determined that the heads were the culprit so we swapped them out. 2½ hours of work and the car was running like a top. He took the car in and blew something like 165 ppm HC and well within limits on CO and NOx.
I just can't buy that putting cats on the car was the only or even the CORRECT solution.
Anyhow good luck with the car.
Old Mar 7, 2011 | 10:52 PM
oldzy's Avatar
Cats are so cooool man... specially when they glow orange.
Old Mar 7, 2011 | 10:53 PM
Well I talked to the guy he said the engine was rebuilt but had to put cats on because it wouldn't pass. But after I get my plates I'm ditching those cat's even I said why put them on the car never came with them and wasn't made for them. So simple taking off the cat's and putting a exhaust system on.
Old Mar 8, 2011 | 02:32 AM
Bluevista's Avatar
Registered
Old Mar 8, 2011 | 04:13 AM
  #31
Aceshigh's Avatar
Originally Posted by Bluevista
ROFL.gif Good stuff.
Old Mar 8, 2011 | 04:31 AM
  #32
442_Mustang's Avatar
x 2 on the last 2 posts!!!
Old Mar 8, 2011 | 08:22 AM
  #33
Run to Rund's Avatar
The first word you wrote to describe the engine was "mild". So, it sounds mild and you want it to sound meaner. . .put in a mean camshaft and do what the others said above; perform a "meaner" build, and spend accordingly. Expect possibly shorter plug life, lower gas mileage, etc. I'd start with a bigger camshaft, and expect to use the engine at a higher rpm band because of it. You may need more differential ratio (higher numerically) to help keep the engine at higher rpm, a looser torque converter, etc. A big cam with "mild" gearing and stock torque ocnverter won't match well.
Old Mar 8, 2011 | 08:35 AM
  #34
cutlassjoe's Avatar
lol! I love that line. I used to say that before I had the 350 redone. Someone would say, boy sounds tough, I would say..."yep, pulled the number 7 plug wire, bumped the timing, and richened up the Rochester." Nothing sounds better or more unique than a beefed up Olds!
Old Mar 8, 2011 | 08:55 AM
  #35
oldzy's Avatar
All you need to do is ask yourself... what would Brian Boitano do?
Old Mar 10, 2011 | 04:54 PM
  #36
this is a better video doesn't sound bad
http://www.youtube.com/watch?v=j1Vbehhy-Rw
Old Mar 10, 2011 | 09:47 PM
  #37
64Rocket's Avatar
Don't sound to bad. I bet if you take the cats off it will be just what you are looking for.
Gene
Old Mar 10, 2011 | 10:08 PM
  #38
oldzy's Avatar
I like the sound of these myself. And of course... everyone knows the *** end of a 1972 Cutlass Supreme looks the prettiest.
http://www.youtube.com/watch?v=INy9G3OaQd0
http://www.youtube.com/watch?v=Fffrp10NkMs (sound @ 1:45)
Old Mar 11, 2011 | 12:27 PM
  #39
71 Cutlass's Avatar
One of None W-31
When the compression was raised in my 71 to 10.5:1 from the original 8.5:1 (more like 8:1 in reality) not only was the car louder but the entire car shakes just idling.
Old Mar 11, 2011 | 01:08 PM
  #40
Coltonis's Avatar
Yeah haven't gone through emissions with my Cutlass on account of it still being in storage (Ziploc's), but I got a '72 Dodge Truck a couple years ago and the guys down at the check station knew me by name by the time it finally passed. It was failing BAD - so I fiddled with everything; mixture, timing, idle speeds... I was about ready to pack some cotton ***** in the exhaust pipe when I just happened to bump a hose with my arm and the engine sound changed - turned out the PCV valve seal had gotten dried out and shrank enough to where it wasn't sealing. Popped a new PCV valve that fit real snug into the gasket took it back. BAM! passed with flying colors and I'm talking a healthy margin from the max... couldn't beleive it that such a little air leak demolished the performance.
Cats in my mind = cop out.
Maybe add some of those electronic exhaust cutout that lets the exhaust dump straignt from the headers/exh. manifold. That would make it sound pretty loud/mean I bet.
Also, my car and truck both had glasspaks for mufflers and both engines sounded pretty dang mean to my ears when they run/ran. Any good mufflers are going to -well- muffle the noise.
