How isn't this a common problem
So I have recently realized there may be an issue with my 4 speed to olds 350 mating. This is my first project and I tend to avoid transmission talk because its often complex, anyway, what are my options to make it work? My cranks are both automatics I believe because they have the center hole that comes to a funnel like shape, I assumed this was a common issue considering it's a common engine to an extent and many run a standard trans, what's the deal!!!
Or, you can use the aftermarket conversion pilot bearing, which requires you to either trim the end of the trans input shaft or to drill a clearance hole in the end of the crank (which is much less critical than the machined bore required to use the factory pilot bearing). Be aware that some folks here have had problems with these aftermarket bearings. I have no first-hand experience so I can't comment either way.
I deleted my post as I went back and found some old threads, so really, dont I just need to either make the hole deeper or cut the shaft and install the bearing?
Nope. It's either use this and cut down the input shaft, or modify the crank.
What you have to remember is that Oldsmobile was primarily into luxury and not performance so automatic transmissions were the norm for them. That's not to say that they didn't make performance cars, but it wasn't their main concern.
To clarify, the factory manual transmission cars had the crank bored with a precision hole to accept the factory-style pilot bearing. The aftermarket conversion bearing fits in the shallow recess that normally accepts the pilot on the AT torque converter. This provides the proper centering accuracy for the manual trans input shaft, but the recess in the crank is not deep enough for the input shaft. This is why you either need to cut about 3/4" off the end of the input shaft or bore a non-precision clearance hole in the crank. People have manually drilled this hole, but it's not easy with a hand-held drill, as you need to work your way up in a lot of steps and can easily spend the money in buying drill bits. Personally I don't like the idea of shortening the input shaft as it prevents using that trans in a normal application.
I tried the conversion bearing....and it failed within 500 miles.
The bearing was not concentric to the crank, and ate itself.
Could not shift into reverse either.
Drilling the crank for clearance is harder than picking fly crap out of black pepper with boxing gloves.....that material is harder than anything metal I have come across.
Best bet is to have the crank drilled properly, and install a BCA7109 bearing.
Still, how is this not a perfected conversion, someone wanting a standard trans isn't that weird, for there to be only one option seems odd
The crank just is not machined for it. You have two options as already outlined in this thread.
Unfortunately no matter how much you may want a third option, it's just not there.
So here's how I see your options....
1. Get the conversion bearing and cut down the input shaft
2. Disassemble the engine and have the crank machined to accept a factory bearing/bushing
3. Find a crank that is already setup for a manual transmission
4. Use an automatic
5. Find a Chevy.
Not sure what else to tell you.
4. Use an automatic
5. Find a Chevy.
4. Use an automatic
5. Find a Chevy.
4. Use an automatic
5. Find a Chevy.
So the answer I was looking for is no there is not a bushing to use, I understand the previously mentioned options. What I do need to know is all of the places where I may find it, aside from the previously mentioned mondellos
And a Chevy certainly isn't an option
455 Olds 442
Aug 3, 2014 06:30 AM
