How does this cam look/
Old Aug 29, 2022 | 11:25 AM
Toocool's Avatar
Im going to be rebuilding the little 330 in my Vista. I talked to the local machinist about it and he pulled his Comp book out and turned to the page that had this cam listed, in the book it says this cam has better torque and lower rpm power. When I got home I looked it up and on the Summit site it says for engines up to 7.4. I know a cam will act different in a 330 than a 455. So how does this look? I just want to help that little engine pull that heavy Vista Cruiser up hills a little better.
COMP Cams 42-221-4 COMP Cams Xtreme Energy Camshafts | Summit Racing
Old Aug 29, 2022 | 03:00 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That looks like it will work fine with a 330. What compression are you planning on?
Old Aug 29, 2022 | 05:20 PM
Toocool's Avatar
At this time i'm looking at the stock compression ratio of 10.25 unless I find a little lower compression pistons.
Old Aug 30, 2022 | 04:13 AM
66SportCoupe's Avatar
Do you know if your 330 is a 45 degree lifter angle or 39 degrees? It will matter with that cam.
Old Aug 30, 2022 | 05:15 AM
Toocool's Avatar
Its the original '67 engine. My machinist says it works for this engine.
1965F85_scholten
Oct 11, 2013 05:49 AM
krooser
Jan 7, 2013 12:57 PM
coppercutlass
May 30, 2012 03:40 PM
pontiac1
Feb 11, 2012 06:30 PM
64oldsguy
Aug 7, 2011 07:56 AM
