hoursepower for a 403
Hey, I have a 403 oldsmobile engine that I'm about to build up. I'm going to be using some of the oldsmobile parts that I have laying around. I was wondering if anyone would know what my output would be around with this engine combo.
- 403 with .030 over bore
- milled 1979 350 heads about 70cc (some porting)
- cam lift: .450" in/ex duration: 274@.006" lift and 218@.050"
- edelbrock intake mailfold 3701
- 9.5:1-10:1 c/r
- 750cfm Q-jet carb
- 9.5:1-10:1 c/r
- 750cfm Q-jet carb
I would rather see you use a set of early heads (1967-1972, #4-7a), and have the head bolt holes opened up, but if you must use these castings, get some bigger valves in them.
1.995/2.07 intakes, and some 1.625 exhausts.
If you don't, you will cut off some 40 hp.
From your post, I would believe you are not in the states...posting your location can help with getting/obtaining parts, castings, and good work done locally.
Where you are at now, 250 hp, depending on tuning, cold air, exhaust, accesories, etc.
JMO
Jim
How much do you think I could gain from a bigger cam and maybe a better flowing intake. I was thinking about getting the Edelbrock RPM Performer 7111 intake manifold and a cam with: lift in/ex .496"/.520" advised duration 290/300 @.050 224/234. What do you think?
Should I get my crank balanced? I'm trying to get a good 400hp.
My crank is in the machine shop getting the journals polished.
My block is also in the machine shop; its getting it's overbore right now.
I am going to be using KB/Keith Black hypereutectic aluminum pistons which have a small "D" dish in them.
88hurstolds
January 20th, 2020 11:39 AM
