Hot air choke tubes,and gasket
Old May 27, 2012 | 11:46 PM
Nasty455's Avatar
XCELERATIONRULES!
1976 Olds 350.
I'm wondering what to use for a gasket?
I'm not using the choke,with the stock intake,as I'm converting to Holley with electric choke.
I've painted the manifold and need to seal it.
Thanks.
Old May 28, 2012 | 05:14 PM
Lady72nRob71's Avatar
Use a stock type gasket which is a material that will take the intense heat. make yourself a custom blockoff plate and just bolt it on!
Old May 28, 2012 | 07:34 PM
Nasty455's Avatar
XCELERATIONRULES!
Any idea what the gasket is actually called?
Not sure if it's found in the carb,or emissions section.
Some call it a stove gasket,but I've been unable to find it anywhere.
Thanks.
Old May 28, 2012 | 11:02 PM
70Post's Avatar
Try a FelPro PN 72586...works on a '70-2 car and likely the same on yours.
Old May 29, 2012 | 01:22 AM
Nasty455's Avatar
XCELERATIONRULES!
Thank you,much appreciated.
Old May 29, 2012 | 05:05 AM
Choke stove is what it is called, int he fuel/air / carb section.
WTony
Dec 3, 2014 04:16 PM
WTony
Sep 12, 2014 06:10 PM
WTony
Jan 4, 2014 07:20 AM
WTony
Jan 1, 2011 05:32 PM
Gary's 2 442-S
May 3, 2010 08:58 AM
