Hooker Headers
Old Jan 11, 2003 | 09:07 PM
spikey0922's Avatar
Talking
Today I just finished installing hooker competition headers on my 71 olds cutlass. It was quite a hasle today as it took from 9am-6pm to do this. I had to heat the block to get the bolts out, move the tranny cooling lines to get the headers through,take out the oil filter housing ,and get those headers up there. Then the drivers side I had to shave a bolt down to get the header to bolt on the head which was succesful however one tube is touching the frame and that bolt...
I was wondering if there are any good modifications that are not too expensive I could consider doing to prevent the headers from melting the wires, or even the brake lines that are about 1 inch from one of the tubes...I am worried about the headers getting so hot that it could damage some of the parts near them...Any suggestions?
Also I had a scare today as I was dumb to not put a new gasket in on the oil filter housing...I went of the garage to get ready for a nice test drive after everything was completed,then smoke everywhere...Oil was squirting rappidly out of the housing all over the headers which gave me a scare....Im hoping I could get some tips from you guys to see what I should consider in doing after having the headers installed to be safe.
Thanks alot!
[ January 12, 2003: Message edited by: spikey0922 ]</p>
Old Jan 11, 2003 | 11:31 PM
EdsDelta's Avatar
The Charter Member
Post
Good point. You need to look into getting some heat shielding tape. (edelbrock and local car shops should have this).. It wraps around the header tubes and will prevent nearby wiring or tubing from heating up and melting. Personally, I would add a steal-braded lining over the break lines. You cant take the cheap way out with your break system, for obvious reasons.
JSGD1966
Mar 20, 2009 06:47 PM
JSGD1966
Jan 14, 2009 08:39 PM
JSGD1966
Nov 12, 2008 06:36 AM
JSGD1966
Oct 14, 2008 10:25 AM
JSGD1966
Aug 27, 2008 07:46 PM
