Holley valve Covers compare to OEM For Size
I’m thinking of replacing the current valve covers 1969 vintage on my 1975 350. I was going to use these Holley valve covers. Does anyone know if they are wider or taller than the OEM ones. I can’t get the oil leaks to stop with the old ones. I have tried new gaskets.
Thoughts?
Thoughts?
They are very close to the stock height. Do they come with the bolt in baffles? I did fine with factory replacement Grommets without baffles. Get the rigid core rubber valve cover gaskets and torque to spec.
I don’t have any baffles for them. They were used on the old original heads. For some reason we didn’t use them when I put the #5 heads on new cam and new valve train. I couldn’t use the scorpion rockers I had.
someone recently posted some baffles they made for some VCs....i doubt i could find that thread....maybe theylll see this one and post the pic. IIRC it was just some sheetmetal loosely formed to the inside of the VC. I cant recall how they attached. OE ones (steel) were welded, that may not be an optional on your alloy ones, you may have to tap those holes and use loctited screws
edit heres the thread
https://classicoldsmobile.com/forums...6/#post1382824
Mine are real close to yours, Here is what I did. I did have to grind off a little of the raised ribs to fit A/C box on passenger side. 87 Cutlass 350 sbo. Sorry not shown. Add a flat piece of flat metal over the holes with washers in between. To give a little space for air.
On 73-77 they fit without grinding under A/C box, tight fit to assemble ( farthests bolt down is sucker to assemble), but not that tight it would hit A/C box when engine is "rocking". Will fit even with .5" valve cover spacers.
Will pay out if you make a bigger splash shields, factory got them right on their covers.
