Holley 4160 to 4150
Old Mar 5, 2012 | 04:23 PM
jag1886's Avatar
Holley 4160 to 4150
Yesterday I converted my Holley 80457 to a 4150 with a rear metering block and added a quick change secondary top. Now after I get the car broken in I can dial it it in properly. It was pretty simple to do, I got the cathedral bowls off a junk Holley I bought off ebay, the secondary kit was from Quick Fuel, I also added a heat dissipator under the carb while I had it off.
Old Mar 5, 2012 | 04:26 PM
jag1886's Avatar
After I got the carb back on I bent up a set of hard lines for, I thought it would look cool to try and duplicate a factory look to the fuel lines, I thought the copper plated steel lines kind of copyed the look of the tri-power set ups. It was pretty easy to do I got all the parts from the local hydraulic shop.
Old Mar 5, 2012 | 05:06 PM
defiant1's Avatar
Lookin' good. What primary/secondary jets did you use? What size pump discharge nozzle did you use? Have you had a chance to fine tune it?
I got a 4150 and am looking for some performance ideas for my 350.
d1
Old Mar 5, 2012 | 05:07 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Wow, looks great. Nice job on the lines, too.
It'll be interesting to see if you notice a performance difference.
Old Mar 6, 2012 | 06:35 AM
jag1886's Avatar
d1
I used 65 primaries, 69 secondaries, and a .31 discharge nozzle. After I get this engine broken in I'm going to run it over to the shop and have them run it on the dyno to get the jetting and spring rate on the secondaries dialed in.
Old Mar 6, 2012 | 09:13 AM
defiant1's Avatar
Cool, please post dyno results when you can.
d1
Old Mar 6, 2012 | 09:44 AM
Rickman48's Avatar
I've done the same thing on a 396 BBC, with excellent results!
Few recomendations, though;
Get the fuel line away from the heater hose,
I used the black spring in the secondaries,
the white eccentric for the bigger accelerator pump,
2 steps up on the pump squirter
I was at 68 primary and 88 secondary - plugs were perfect!
Went 13:53 @ 109.88 w/T-400, 3:55's + stock converter, in a 2-dr wagon!
Also had a torquer manifold with a 1" spacer.
350TurBRO
Aug 14, 2014 08:12 PM
Stevec
Feb 12, 2014 03:06 PM
g77rvd
Apr 7, 2011 09:34 AM
g77rvd
Mar 26, 2011 02:55 AM
Swoopy
Oct 18, 2010 08:55 PM
