Hi
Old Mar 1, 2021 | 11:55 AM
Barneybrendan's Avatar
Hi
Hi from the UK
we have a 403 oldsmobile engine in our 1970 pontiac lemans.
will be after some engine advice later on best pistons ect .
It has 455 heads thats what we know so far ,but everything ive read is about 350 heads on the 403.
Old Mar 1, 2021 | 12:08 PM
Originally Posted by Barneybrendan
Hi from the UK
Welcome. The 455 heads will flow much better than 350 heads, but there are two things to watch out for. The first is compression ratio. The 455 heads have about 80 cc chambers. The 350 heads have about 64 cc chambers. You need to either mill the heads or use flattop pistons to get to an appropriate CR with that combo. The second is port mismatch. Since the 455 heads have larger ports, there will be a mismatch with 350 intake manifolds. Only a very few intakes have sufficient material to be port-matched to the 455 heads. The E-brock Performer RPM is the most common. The ancient E-brock OL4B is another. Most factory iron manifolds should have enough material also.
Old Mar 1, 2021 | 12:25 PM
hi it does have the E-brock performer fitted.
Old Mar 2, 2021 | 12:40 AM
Block is 554990 (1977) 403
Cylinder heads are E 403686 (68-70) 455
E brock rpm intake
cam is Elgin pro stock E-908-p
will open engine up to see what's been done ,I do know guy said standard pistons,and roller rockers,double valve springs.uprated oil pump,new chain.
Old Mar 2, 2021 | 05:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
How does it run? You will still be around 8 to 1 compression with stock replacement pistons. Measure how far below deck they are at TDC. Those heads will have a slightly smaller chambers, my 4A heads were 86cc. They also have a better flowing intake port and a much better exhaust port than the stock 4A heads. A set of KB Hyper 6cc or Autotec forged pistons would wake it up a bunch. Looks like a copy of the W30 cam in a possibly 8 to 1 motor. Even with a piston upgrade, I would run a 2500+ stall converter with that cam.
Old Mar 2, 2021 | 05:15 AM
How does it run? You will still be around 8 to 1 compression with stock replacement pistons. Measure how far below deck they are at TDC. Those heads will have a slightly smaller chambers, my 4A heads were 86cc. They also have a better flowing intake port and a much better exhaust port than the stock 4A heads. A set of KB Hyper 6cc or Autotec forged pistons would wake it up a bunch. What are the specs on that cam?
Old Mar 2, 2021 | 05:17 AM
first one under orange band
Old Mar 2, 2021 | 05:19 AM
Don't know how it runs as we bought it as a fire damaged car
Old Nov 22, 2021 | 11:24 AM
Water must of got in from fire truck ,2 rusty rods
no roller rockers
jsouth
Oct 4, 2020 09:00 PM
rock88
Jul 20, 2020 09:41 PM
Khaled Ghraizi
Apr 14, 2019 10:00 AM
Troys Toy 70
Nov 19, 2011 09:06 PM
Gbobby
Feb 27, 2009 04:23 PM
