Help with starting the car after it's warmed up
Old Jun 13, 2017 | 01:02 PM
Arctictoaster's Avatar
Hey guys new here.. so I have a 1972 cutlass supreme 5.7l 350. 2 door convertible. I have upgraded a good amount of things, the problem I am having is after the engine is warmed up. In the morning the car starts right up, after it reaches about 190 degree and I turn it off wait a few minutes try to turn it on again and it struggles. I replaced the thermostat with a 180.. any suggestions?
Old Jun 13, 2017 | 01:47 PM
RROLDSX's Avatar
Does the motor turn over normally and it just won't start or does it turn over slowly?
Old Jun 13, 2017 | 07:48 PM
What do you mean by "it struggles"?
Are you cranking it while holding the throttle slightly open?
Is the yellow wire from the starter R terminal to the Coil (+) terminal connected?
Welcome to ClassicOlds.
Old Jun 13, 2017 | 08:34 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Those Edelbrock carbs, much like factory AFB carbs are known for hot start issues. The fuel boils in the carb, a phonelic spacer or better yet a Qjet or Street Demon carb will fix it right up.
Old Jun 14, 2017 | 08:11 AM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... Possibility the choke is not opening all the way or not staying open after it is warmed up and you shut it off... On the restart, if the engine is warmed up, and choke is closed (or partially closed) starting can be difficult...
Old Jun 14, 2017 | 10:12 AM
rjohnson442's Avatar
Mr. Johnson
Welcome!
After its warmed up take the air filter off and the have someone shut the car off. Do you see fuel still pouring down into the intake? We need to rule out fuel related problems vs electrical problems.
Jonmueller1
Dec 20, 2013 07:27 AM
gearheads78
Mar 29, 2012 08:08 AM
mhartley
Jun 7, 2011 08:25 AM
BlueCalais79
May 4, 2011 03:10 PM
tinner
Mar 24, 2011 03:44 PM
