Help with rocker studs
I recently ordered a set of springs from lunati, the 73195 springs. They said the springs set up at 1.7 inches. Since im going to a adjustable valve train would rocker studs that have a effective stud length of 1.52" inches work, or would i need some a bit longer to be more level with the top of the spring? Also, will 302 roller rockers work on oldsmobile heads? Thanks!
Yes, they will. I am currently running Scorpion SBF 1.72 ratio rocker arms. I was looking for maximum lift. Comp makes a conversion stud if the threads are 5/16" or you can by the Olds specific rocker arms.
These if the heads haven't been drilled for over sized studs.
http://m.summitracing.com/parts/cca-4542-16#
CutlassLegend
September 21st, 2011 02:56 PM
sx455raidercelticfan
January 10th, 2011 12:57 PM
