HELP! Crack by valve cover
Old Mar 20, 2012 | 08:13 PM
Finn5033's Avatar
HELP! Crack by valve cover Posted better picture
Hello, I had another thread going regarding my motor being sluggish. As I was looking at my carburetor I noticed a crack by my left valve cover. I wanted to start a new thread as this is something I just noticed. I had noticed a little bit of oil there and had assumed that the valve cover needed a new gasket. I am attaching a picture with the spot I am talking about circled. If you click on the picture it gets bigger. Please let me know what you think if anything. Disregard the coolant you can see in the picture, that was from me changing the thermostat.
Old Mar 20, 2012 | 09:06 PM
I'm sorry to say that that picture is too small and I can't see any crack.
Is it possible to post anything bigger, or to indicate where the crack can be seen?
Old Mar 20, 2012 | 09:08 PM
Finn5033's Avatar
Old Mar 20, 2012 | 09:09 PM
Finn5033's Avatar
If you click on the picture it gets bigger. I don't know if you tried that already. You can see it by the coolant
Old Mar 20, 2012 | 09:55 PM
fourtwenty's Avatar
if you're talking about the gap between the intake ports ? That is just a gap from the intake gasket. I don't see a crack anywhere. Could be leaking oil out there which would give you vacuum loss, replace the gasket. Orrick
Old Mar 21, 2012 | 04:03 AM
It don't get much bigger...
Old Mar 21, 2012 | 05:16 AM
Finn5033's Avatar
@fourtwenty
I circled the spot that I am concerned about. Is this what you are seeing as well?
Old Mar 21, 2012 | 05:42 AM
Oldsmaniac's Avatar
For sure not a crack and not a problem as this is a non critical sealing area for engine running as it is in between 2 intake ports. It appears there is a square nut just laying there??
Old Mar 21, 2012 | 05:45 AM
bigD's Avatar
that is not a crack, likely any oil you are seeing is coming from your valve cover gasket...
Old Mar 21, 2012 | 05:46 AM
gearheads78's Avatar
car guy
Looks like part of the intake from here.
Old Mar 21, 2012 | 05:48 AM
+1.
That's just a gap in the gasket.
It may or may not indicate a poor seal into the crankcase, which would tend to leak a bit of oil and provide a little "extra" crankcase ventilation.
Nothing to worry about.
Old Mar 21, 2012 | 05:55 AM
frankr442's Avatar
Relax. As Fourtwenty said, it's just space between the head and the intake gasket. Perfectly normal. Nothing is really getting sealed right there anyway, its between the intake ports. It wouldn't hurt to change it if you're having driveability issues. I dont really like repeating what everyone else just said. I would have been post #8 but I got interrupted by a mechanic with a big estimate. Can't the people I work with see that I'm busy?
Old Mar 21, 2012 | 06:04 AM
X5 - gap in gasket, no problems there!
Old Mar 21, 2012 | 06:06 AM
Finn5033's Avatar
Alright guys that is a relief. I am new with all of this so when I saw that it scared me. Thanks for looking.
Old Mar 21, 2012 | 06:33 AM
To clarify the above posts, your car has an original-style thin metal intake gasket, which is why if you look closely inside the circle in your photo, you can see the thin sheet metal bowed up. Since this is in an area where there is no clamping and thus nothing to seal, do not worry about it.
Old Mar 21, 2012 | 06:38 AM
Rickman48's Avatar
Put a little carb cleaner across it while running, if it changes the idle - it's leaking.
Then dab some silicone across it, if it bothers you!
Old Mar 21, 2012 | 06:39 AM
Finn5033's Avatar
Thanks again for the info
OldsMotion
Feb 16, 2011 01:32 PM
malibu406
Feb 5, 2010 10:19 AM
my69olz
Oct 22, 2009 07:44 AM
Jamesbo
Dec 14, 2008 10:54 AM
Pitbull2o08
Jan 16, 2008 07:19 PM
