Heater control valve
Old Nov 22, 2017 | 01:12 PM
Oldssupreme's Avatar
Chris
Hi everyone! I have a 72 cutlass with a 350 and AC. So I've included some photos of the NOS heater control valve I bought today. It has the base that screws onto the manifold, the vacuum nipple, and the heater hose attachment point. However, there is another part that's shown in the second photo that is threaded on the inside diameter. Is this the wrong part or am I missing something. I don't seem to have anything that would connect to this.
Thanls!
chris
Old Nov 22, 2017 | 03:01 PM
Nice pictures. You got everything in focus, which many folks have trouble doing.
So is there a question that goes along with these?
Old Nov 22, 2017 | 03:26 PM
Chris
Lol. Thanks Fun71. I didn't realize that my message didn't come through. Your comment gave me a good laugh. I needed that today! Thank you.
Old Nov 23, 2017 | 05:55 AM
Cars with the automatic climate control had a sensor that screwed into that port. Cars with manual A/C like yours don't use it.
Old Nov 23, 2017 | 07:45 AM
Chris
Thank you both very much!
Happy Thanksgiving!
Chris
Old Nov 23, 2017 | 07:23 PM
Chris
May I also ask if the one in the photo in the first post is correct for my 72 350 with AC? The one I have on now has a lever connected to the vacuum sort of like in the attached photo above. But I'm not sure if that was replaced or original. Thanks!
Old Nov 24, 2017 | 03:25 AM
This lever-actuated valve is for a Buick. Olds used a valve that screws into the intake manifold.
Old Nov 24, 2017 | 04:47 AM
Chris
Ok thanks Joe. So the one in the photo above with the pink ribbon which is the one currently on my car was probably a replacement before I got the car?
Old Nov 24, 2017 | 06:59 AM
Note that this valve has a pipe thread fitting to screw into the intake. The Buick valve you posted previously has two hose barbs and goes inline in the heater hose. In any case, Oldsmobile typically used a valve like the one in your first photo. The correct P/N for your car is 411822, which is a normally closed valve that opens when vacuum is applied.
Old Nov 24, 2017 | 08:26 AM
I think many people switched to that type valve with a lever and detached vacuum canister as they don't leak coolant if the vacuum diaphragm fails. The Olds style valve will leak coolant if the diaphragm fails. That irritated me to no end back in the 80s-90s when I was daily driving my Cutlass to school and work.
Old Nov 24, 2017 | 08:35 AM
I'll second this. In fact, I got so tired of replacing the leaking valves on my 84 Custom Cruiser that I put in a nipple and used a plastic Chevy style heater control valve. The Chevy valve has the external vacuum actuator, the plastic doesn't corrode, and since it's inline in the hose it's very easy to replace. Of course, that was a normally open style and won't work on the 72-earlier A-body cars.
Old Nov 24, 2017 | 06:03 PM
Chris
So if you both had issues with these type leaking, then maybe I should just keep the current one in. I had planned on replacing it for aesthetic reasons (the current one is not leaking).
Chris
Old Nov 25, 2017 | 05:35 AM
Chris
In fairness, the ones I've had trouble with are the made-in-Mexico aftermarket ones from Four Seasons (and even a new ACDelco from the dealership - also made in Mexico ).
Old Nov 25, 2017 | 12:18 PM
Chris
I don't remember the brand this one is. I'll have to look at the box. But if it's NOS, does the rubber diaphragm break down over time even if it's not being used?
Old Nov 25, 2017 | 12:48 PM
Chris
Here's the valve. Any insight to where this is made and if it's any good? Thanks!
chris
Old Nov 25, 2017 | 02:29 PM
Chris
Also the part number is different than what you listed. Maybe I got the wrong part?
Old Nov 25, 2017 | 02:51 PM
yellowrocket's Avatar
my '72 350 2bbl
had the lever type one that was threaded into the intake. Often wondered if mine was factory and if they were reproduced.
Old Nov 25, 2017 | 03:04 PM
Chris
Hi yellow rocket. Yeah I'm wondering the same. When I looked on rock auto they had the same type as my new one.
Old Nov 25, 2017 | 05:49 PM
I have the same valve on the shelf for my car.
It is stamped with:
TYPE H25
RANCO
COLO, USA
The backside has an ink label:
H25-124
The valve is normally open and takes vacuum to close.
Just today I was working on the car, changing the heater core and I'll install the new heater valve tomorrow. I connected a vacuum gauge to the heater valve vacuum hose on my car and it has no vacuum with the temp slider on WARM and vacuum with the temp slider on COOL, so this valve matches my car's vacuum operation.
I recommend you check the vacuum operation on your '72 to ensure it matches your heater valve as my '71 operates opposite of what the factory manual describes per Joe's posts.
Old Aug 7, 2021 | 07:54 PM
arcflashfisher's Avatar
What part am I looking for?
I have been looking for answers on my heater valve and happen to stumble on this old thread and was hoping someone would read this and have an answer. It's frustrating to know something exists but can't get your hands on one. Kind of like Big
foot. I have a '75 Delta Convertible and am replacing the heater valve. My valve has a screw in heat switch. Does anyone know what the technical name is and where I can get my hands on one? Thanks for your participation.
Old Aug 7, 2021 | 08:50 PM
rocketraider's Avatar
Oldsdruid
It's called a thermal or low blower range relay. Its function is to allow low speed blower operation when the HVAC control is in OFF and coolant temp is 120° or higher.
From 1974 CSM. 1975 will be similar. It was eliminated for 1976.
Old Aug 7, 2021 | 09:06 PM
Thanks, I've been having a hard time finding it online. Any suggestions?
Old Aug 7, 2021 | 09:15 PM
Oldsdruid
I honestly don't know where you'd find one short of an old stock or junkyard piece. I couldn't get a good part number from my Nov 73 parts book and I don't know if aftermarket ever supported it.
Worst to worst, if you can't find one, and not having it interferes with blower operation, leave it unplugged and install a jumper across the brown wires in the plug.
Old Aug 7, 2021 | 09:20 PM
Old Aug 7, 2021 | 09:23 PM
That's probably what's going to happen. Thanks
Old Aug 8, 2021 | 05:56 AM
P/N 6490448 Switch, Thermal Blower (Group 9.275). Used on 1973 cars with automatic A/C (second design with two terminals) and all 74-75 cars with auto A/C. There's at least one on ebay right now for $10. As Glenn noted, there's nothing magic about this. Despite being called a "relay", it's just a thermally operated switch that closes when coolant temp reaches 120 deg F. This provides power to the blower motor so that the auto system isn't blowing cold air if you turn the heat on before the engine is warmed up. The 1971-older cars with auto A/C didn't use it either. The 1971-72 and first design 1973 cars used a one-terminal version that grounded through the switch body.
Old Aug 8, 2021 | 06:22 AM
Thanks Joe, I should be getting my 350 back from the shop in a couple of weeks and I'm trying to wrap up a few loose ends. I can now check this off my list.
Old Aug 8, 2021 | 06:40 AM
Hate to be a pest joe, but could you send me a link to the one on ebay. I am having trouble with anything coming up.
Old Aug 8, 2021 | 06:50 AM
Oldsdruid
Small wonder I couldn't find it. CSM calls it one thing and parts book another.
👈 didn't know what 👉 was doing. I bet being a GM parts man was loads of fun!😀
Old Aug 8, 2021 | 10:00 AM
Yeah, I cheated and started in the Illustrations book.
Old Aug 8, 2021 | 10:02 AM
  #31
If you just type the part number into Google, ebay links are the first thing that come up.
https://www.ebay.com/itm/25491728132...0AAOSwG79gXdNO
Old Aug 8, 2021 | 10:09 AM
  #32
You da man. I ended up finding one earlier on ebay and they wanted $40. I think I'll order the one you found. Now I can afford a new pair of fuzzy dice for the mirror.
jensenracing77
Mar 19, 2014 04:08 PM
zodiacblueS
Apr 7, 2012 02:38 PM
Mister
May 13, 2011 03:53 PM
blue72regency
Dec 12, 2007 01:12 PM
bjtstarfire
Dec 15, 2006 10:14 AM
