Header/ trans Linkage clearance issues
Old Nov 11, 2014 | 07:25 PM
NMcCarthy's Avatar
Okay so I have an 86 cutlass supreme with what i believe to be a TH350
problem is the headers that came with the car when installed the C looking attachment that the shift rod connects to on the trans. is hitting the header about an inch before the collector when you pull the gear selector down thus not allowing you to manually downshift past drive.
Is there a solution to this issue without changing headers.
if not what are some good clearing headers for this car. it has an olds 350 in it now.
Thanks for any and all input/opinions
Old Nov 12, 2014 | 05:32 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If you cut off the excess rod past the clamping point, will it clear? I have done that before, did the trick.
Old Nov 12, 2014 | 09:11 AM
NMcCarthy's Avatar
Unfortunate it is not the rod it is the actual piece thats bolted on tranny the rod goes through it looks like a C and the rod goes through and the cotter key goes through hole in rod.
Thanks for replying look forward to more input
Old Nov 16, 2014 | 08:03 AM
Lars's Avatar
Just beat/dent the header collector, it's better than trying to modify the linkage...
Pewter442
38
Oct 5, 2014 11:35 AM
Napoleon1991
Mar 31, 2014 06:46 AM
rmoths
Dec 5, 2012 06:50 PM
rmoths
Nov 13, 2012 08:09 AM
john71
Aug 1, 2010 10:22 AM
