Have a Look at these Spark Plugs
Old Oct 23, 2012 | 10:54 AM
jpc647's Avatar
Hi Guys,
I'm hearing a faint "popping" noise as I accelerate through second gear on my Cutlass, and am trying to determine lean/rich condition. I thought "popping" was a rich condition, but now I'm not so sure. I also smell gas when the secondaries open sometimes, but can't find a leak. Starting to think there might be a restriction somewhere in the line, or the pump not keeping up.
Old Oct 23, 2012 | 12:34 PM
The_Jeremiah's Avatar
dont suppose you have 2 plug wires crossed? maybe a bad coil? something along those lines? plug doesnt actually look bad to me.
Old Oct 23, 2012 | 12:46 PM
panos's Avatar
Plug is on the lean side.
Old Oct 23, 2012 | 12:50 PM
jfb's Avatar
jfb
I would if it is a holley carb get slosh tubes for the secondaries. The gasoline goes to the back of the secondary side when it is upon aceleration and it needs a longer feed point to pick this up.
Old Oct 23, 2012 | 01:26 PM
cutlassefi's Avatar
Plugs look fine to me. Where is the popping coming from? The exhaust or thru the carb? Is that the only time it does it? How's it run otherwise?
Old Oct 24, 2012 | 05:29 AM
jpc647's Avatar
I was sort of thinking that, the white on the top lead me to believe it's running lean.
Unfortunately, it's an edelbrock carb.
The popping is out of the exhaust. I can only hear it if I'm next to a jersey barrier or going under an overpass and it's usually at night where it's quite. If I rev the motor in park or neutral to say 4k(estimate), let it wind down to 2k(estimate), and rev it back up to 4k It'll pop on the way back down to idle. Not sure if related or not.
I just wanted to see what others thought of the plugs, I don't want to burn a hole in the piston by running lean...
Old Oct 24, 2012 | 05:39 AM
sammy's Avatar
Sammy70 455 Supreme
Definitely on the lean side!
Old Oct 24, 2012 | 07:12 AM
TripDeuces's Avatar
The plugs look good to me but maybe a tad on the lean side. Popping through the exhaust is a lean condition but only shows when letting off the accelerator. I haven't heard it while driving normally but who knows. Is it surging?
The only time I've usually heard any popping through the exhaust is when headers were added or the exhaust freed up a lot like with bigger pipes without jetting up the carb. None of this is written in stone though as every engine combo might react differently.
Old Oct 24, 2012 | 06:46 PM
jpc647's Avatar
Whoa!? You know what!? I remember reading that somewhere. The last owner did put a dynomax muffler and new exhaust throughout the whole car. It was mentioned the carb was never touched. Hmm. I wonder if I should get the calibration kit for the e-brock carb I have then.
bob p
Apr 10, 2015 01:55 PM
jpc647
Aug 29, 2011 07:40 PM
65Delta88
Sep 11, 2008 10:13 AM
KQQLCAT
May 6, 2008 08:18 PM
The_Jeremiah
Jan 26, 2008 01:56 AM
