Harmonic balancer question
Old Aug 10, 2020 | 01:00 PM
Napoleon1991's Avatar
After some time spent diagnosing a ticking / squeaking sound coming from my 403, I found my harmonic balancer to be completely separated. There are 2 holes drilled into the outer edge of the balancer from when the engine was balanced by whoever rebuilt it. My question is whether or not I can simply just replace the balancer without throwing the engine out of balance?
Old Aug 10, 2020 | 02:39 PM
dc2x4drvr's Avatar
Yes
Old Aug 10, 2020 | 02:43 PM
Yes
cool thanks. Are all factory original balancers the same, or do I have to order one with the exact same part number ?
Old Aug 10, 2020 | 05:33 PM
Yellowstatue's Avatar
The drilled holes are there to balance the balancer.
Old Aug 11, 2020 | 05:24 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As long as it is factory used or a rebuilt original, it will have the same balance. There are aftermarket balancers with add on weights, more pissing around than neccessary.
Old Aug 11, 2020 | 06:21 AM
oddball's Avatar
Go with an OE or factory replacement (I was still getting them from GM dealers in 2001......) and just bolt it on. Post a parts wanted ad on here and someone will offer one.
As mentioned, aftermarket ones do not necessarily have the same weight offset, so it's a bit of a gamble to switch to those. I know ATI and Pro Products both have more offset than stock.
Old Aug 11, 2020 | 07:21 PM
coppercutlass's Avatar
Chevy budget Olds powered
You can have that one rebuilt too.
Gene kerr
Apr 1, 2020 08:07 AM
griffey57
Feb 17, 2017 04:18 PM
wagsk2000
Oct 10, 2016 03:01 PM
jrainwater73
Feb 28, 2015 10:02 AM
Stevec
Aug 12, 2012 03:12 PM
