harmonic balancer
Old Aug 18, 2015 | 07:04 PM
deadeyejedi's Avatar
harmonic balancer
ive been putting my engine back together after installing a new timing chain and gear,and new paint job . im having a heck of a time getting the harmonic balancer back on . i ended up breaking the old timing gear with a five ton puller trying to get that off .and had to tap the new gear on with a block of wood . the balancer is on about an inch and wont go any further without a significant amount of force.i know pounding it on with a large hammer is not a good idea .i sanded both surfaces with 400 grit and oiled before trying to install .are these tolorances that tight?ive been told these should slide right on .any input would be appreciated
Old Aug 18, 2015 | 07:22 PM
cdrod's Avatar
Rodney
Have you tried warming up the balancer? Soak it in a pot of boiling water or heat it in the oven (no more than 200 degrees) to expand the clearance a little. Might be just enough to get it on without resorting to a BFH!
Old Aug 18, 2015 | 07:24 PM
no i didn't try heat yet but might try baking it a bit .give that new paint a test in the process
Old Aug 19, 2015 | 02:46 AM
Google harmonic balancer installer
I've had one like this for decades:
Old Aug 19, 2015 | 03:43 AM
i guess i could go out and buy one if the heat doesnt work .add to the collection of tools ill probly never use again
Old Aug 19, 2015 | 10:02 AM
Do you guys by chance know the thread size of that balancer bolt I could maybe pick up a bolt for a make shift press on my way home from work
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
