Hardly Running
Old Oct 16, 2016 | 09:04 PM
AZ_Brad's Avatar
'71 Cutlass S
Hardly Running
I'm having trouble with my 71 350 Cutlass. Starts fine, but one it gets warmed up, thingso go really bad! It shakes terribly at idle, like it's running on 4 cylinders. Because it's been sitting for a couple years, I pulled the Edelbrock carb and cleaned it well. Now it doesn't run well while cold OR warm, lol. I'm puzzled. Where do I go with this?
Old Oct 17, 2016 | 05:08 AM
Arrowstorm's Avatar
Olds Wagonmaster
Since you pulled the carb and cleaned it, I guess I"d first start there with checking choke adjustment, f/a mix and float settings. Set the floats to factory spec which can be found in the edelbrock manual. I've always had a hell of a time with my edelbrock 1406 until only recently with the addition of a fuel pressure regulator.
But you need to start with the basics first. Float adjustment first, fuel air mix screws and choke.
After that, if it still runs like crap, then you need to look at ignition issues such as timing, spark and all that.
Old Oct 17, 2016 | 05:17 AM
Did you run the old fuel that was in the gas tank. Does it smell foul like varnish?
Old Oct 17, 2016 | 05:21 AM
m371961's Avatar
Anytime a engine has a poor running difference between cold and hot I go to the choke first. Possible vacuum leak after you remove carb.
Old Oct 17, 2016 | 07:18 AM
AZ_Brad's Avatar
'71 Cutlass S
All good suggestions. Thanks! The gas is 6 months old and smells normal. I'll check on the float level and look for vacuum leaks.
Old Oct 17, 2016 | 09:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Another car running like **** with an Edelbrock carb, get in line, many have issues. Check for vacuum leaks, old gas also can cause rough running and may have plugged passages inside.
Old Oct 17, 2016 | 07:10 PM
Cutlass Fan's Avatar
Time for a qjet
Old Oct 17, 2016 | 08:21 PM
You DID check the spark, right?
Old Oct 18, 2016 | 06:08 PM
76olds's Avatar
Hookers under Hood
Did you happen to turn the carb upside down when cleaning?
Carl, uk
Mar 13, 2014 05:43 AM
mjscutlass
Dec 3, 2006 11:23 AM
oldmanolds
Aug 31, 2006 06:03 AM
bluerider
Aug 27, 2006 10:21 PM
<KEN>
Sep 22, 2004 08:39 PM
