going electric
going electric
Well after figuring out not all gm fan clutches have the same bolt pattern I'm going to electric fans what should be the minimum cfm I should be looking at and are the eBay ones worth it I'm down for a while broke po'd so I've walked away before I break anything....needing suggestions I hear the mark 8s and Windstar fans are good for airflow
Why not just find out what clutch your car requires and get that, rather than open up a new big can of worms?
Rockauto can help find you the correct part number. Get one from them or maybe the local parts stores might have one in stock.
For a 350, just get a standard (non-HD) clutch for best drivability.
Electric Fans
I worked with the application of Spal fans before I retired.
The CFM rating for a lot of the pancake motor fans are at zero delta p, which means that the CFM is for the fan all by itself with no radiator up or downstream of the fan.
A CFM vs. delta P performance curve is required to evaluate two different fans.
On the fan clutch question, the fan that we'll be using has more than 100 applications, covering a broad range of brands and vehicle types.
Gerry
Gerry
I'm running mechanical on one car, electrics on another, and a combo on a 3rd.
My advice
-Stick with mechanical fan if at all possible
-If you go electric, forget pretty much ALL ebay, generic electrics, Their cfm means nothing. Check amp ratings, probably a better indicator of flow.
-An average OEM GM/Ford dual fan can easily pull 60 amps. How big is your alternator? Not uncommon on these old cars to have only a 60 amp alternator.
-Use and OEM GM/Ford/Chrysler dual fan that fits your radiator. They typically flow A LOT of air, can be bought anywhere for around $100, and are super reliable. How big is your radiator?
My advice
You need a 100 amp alternator, 70 amp will be questionable. I run dual Dodge Stratus fans, move plenty of air and buy a decent relay setup. The cheap Derale ones burn out and the wiring falls apart.
Here's the deal, if you want to run an electric fan you'll need to upgrade the radiator too. I don't know if you have a aluminum radiator or not, but that helps. Every car I know of (from the factory) that came with a mech. fan that in later year the manufacturer went to electric fan(s) also increased the radiator size.
People think electric fans are the cure for over heating, most times they're the cause of over heating, especially in a custom set up.
I ditched my electric fan set up. I used them as pushers infront of the radiator. On the street I ran a mech fan and h20 pump. At the strip I would take the fan and pulley off and set up the morose electric drive for the water pump and used the electric fans. All that work to gain almost tenth in the 1/4 mile. I drove it once on the street like that and it ran hotter than I would have liked it too but not over heating. I ditched all that crap and went back to the stock stuff with a good clutch . Moral of the story you don't needit the stock stuff is fine. What would the reason for going electric be ?
I've got to thinking and you're right its too much work but I bought a Chevy clutch off a friend thinking hey it gm bolt patterns should be the same......wrong they aren't I drilled my fan.....should have been the first clue to my demise....then I went bolt it onto the pump and the holes on the clutch are closer tho the center than my pump holes....needless to say I threw things across the yard and walked to the store got 10 bucks worth of snack and ate
Think of it as helping folks like me out.
I literally have so much stuff that I can't find the good stuff anymore, tripping over heads, etc. For basically the price of postage you could have proper fitting correctish GM parts in your hand. No redrilling. No hassle. Huge time savings.
I would not miss a used fan clutch
Trying to fix?
Bill, are the blades of just the fan still good or did they smack
a telephone pole when you launched them?
If it is, can you pay the ship for a good used clutch?
If yes, shoot me a pm, we'll work it out.
Getting frustrated
doesn't help a damn thing. Been there, I'm a redhead so, yeah,
I get it.
Getting frustrateddoesn't help a damn thing. Been there, I'm a redhead so, yeah,
I get it.
I have a extra fan and clutch from a Bbo, not sure of condition I wasn't planing on using it. If I can locate it this weekend and check over the fan to see if it's okay your more than welcome to have it. just pay shipping as it was most likely becoming garage art or scrap any ways
Your a great example to those around you. We all need help at some point just pay it forward.
I have bought stuff on the buy now, pay later plan too. I have sold stuff like that as well. I don't count on the payment happening, but sometimes it does. I have been waiting years for a friend to pay for a 350 engine....
Well I value my name so I'm good to my word...now it may take me a bit to sell and get the money but best believe I pay back what I owe and that doesn't sound like much of a friend to me lol
Another option may be see if any members/ friends near you will trade elbow grease for there spare parts/ cash for your project
I know your not near me, but I could use a hand cleaning shop and I am kind of a hoarder Lots of spare parts
I am sure there's lots of options
I admire your initiative toward your project ! Keep up the great work
