Fuel pump replacement
Old May 23, 2008 | 05:30 AM
Colorado Olds's Avatar
We need to replace the fuel pump on the 330 in Josh's '66 F85. Are there any special tricks to this, or is it a simple remove and replace? My father-in-law said there may be some pin that needs special attention - needs to be held up out of the way or something? On my Jeep, all it needed was to make sure the lever got above the lobe that drives it - you just tip the end of the lever up as you place the pump - maybe this is more involved?
Thanks,
Jim
Old May 23, 2008 | 05:49 AM
Rallye469's Avatar
Your father in law is thinking about a chevy that has a rod that connects the pump to the eccentric(is that called an eccentric too?)
Anyway, the olds unit has a lever...attached.
It's straight forward. Just remove it and then replace.
The lever rides off the bottom of a little round barrel that's
bolted on the front of the cam.(located right in the middle of the big sprocket)
Note: the fuel pump lever is not shown here, but would enter from the left side
Old May 23, 2008 | 07:31 AM
Cool - thanks. Sounds like an easy deal then.
Jim
dfire25
Jun 28, 2016 01:37 PM
Mochi
Sep 6, 2014 01:35 PM
Miles71
Jun 14, 2014 02:42 PM
Stevec
May 14, 2011 12:14 PM
mark
Apr 6, 2006 04:33 PM
