Fuel pump mounting question
Old Mar 20, 2012 | 05:01 PM
Nasty455's Avatar
XCELERATIONRULES!
getting ready to re assemble my motor.
The small stud on the fuel pump is bent.
Do these have a part number?
Just replace with a bolt?
I'm guessing the stud is to make install slightly easier...due to clearance issues?
Old Mar 20, 2012 | 05:09 PM
citcapp's Avatar
You can use a bolt no problem or replace the stud either will work. You can find studs at the NAPA store in your local area. The stud make is easier because of the compression on the arm of the pump and holding it in while starting the bolt. this is when a person would like to have three arms.
Old Mar 20, 2012 | 06:16 PM
Nasty455's Avatar
XCELERATIONRULES!
Thanks...it's always the small parts that hold up an engine build...and seem to cost the most.
AK71CutlassS
Dec 10, 2014 04:05 AM
Nor Cal Andy
Mar 29, 2012 07:27 PM
jtriggy
Suspension & Handling
Apr 30, 2010 08:40 PM
Charlie_brown
Apr 6, 2010 11:41 AM
sshriber
Mar 22, 2010 06:16 PM
