Fuel Pressure Regulator
Old Nov 24, 2010 | 10:57 AM
dman0712's Avatar
When exactly is fuel pressure regulator needed? I have a mechanical carter muscle car fuel pump with holley 750dp. At start up I had 9 psi for fuel pressure. That seems high to me. When it was running i didn't get chance to look what pressure was. I was too bust operating the throttle on the other side of the car.
Old Nov 24, 2010 | 11:15 AM
Rickman48's Avatar
Should be fine if it's not shooting out of the carb - the main needle and seat, controlled by the float, apparently have enough pressure to overcome the fuel!
Old Nov 25, 2010 | 10:31 AM
DJS70cutlass's Avatar
Thats too high. Your Holley carb really want's 6psi MAX.
While it may run ok where it is now it would be better around 5.5.
jensenracing77
Nov 18, 2014 05:14 PM
Stevec
May 23, 2014 07:30 AM
1965cutlassragtop
Jul 15, 2012 06:26 PM
KathleenF
May 25, 2011 07:02 AM
Charlie_brown
Oct 30, 2009 08:54 AM
