Exhaust valves
Old Feb 27, 2021 | 10:07 AM
Felipe4's Avatar
70olds
Exhaust valves
I got 1970 cutlass 350 and out of no were it started weird idle changed the spark plugs and wires still did the same so I went around pulling plug wires to see the change in idle. When I came to the passenger side the two middle plugs made no change in idle. Also on the passenger side you can hear the difference in the tailpipes pulled the intake manifold off and found this
Does it look like 1 of my valves mite be stuck open
Old Feb 27, 2021 | 01:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Possibly, usually bad things happen if they stick open. Has any work been done to the motor?
Old Feb 27, 2021 | 03:35 PM
Felipe4's Avatar
70olds
No no work has been done
Old Feb 28, 2021 | 06:24 AM
67OAI's Avatar
Old(s)GuysRule
Are you saying that to your knowledge that motor has never had a valve job?
Old Feb 28, 2021 | 06:34 AM
It looks to me that your intake manifold gasket has been leaking. Did you run a compression test on the engine?
Old Feb 28, 2021 | 09:35 AM
Destructor's Avatar
It looks like your gasket failed at the exhaust crossover port.
Old Feb 28, 2021 | 10:04 AM
Felipe4's Avatar
70olds
Never had a valve job and also replaced the valley pan gasket and did a compression test my numbers were around 120-125. After putting it back together no change still doin the same rough idle
Old Feb 28, 2021 | 10:13 AM
Has the timing chain/gears been changed? Have you checked for vacuum leaks?
69oldsguy
Feb 7, 2021 09:06 PM
tgilligan
Jan 22, 2020 04:32 PM
AK71CutlassS
Apr 19, 2017 12:45 PM
Sarum
Mar 26, 2015 09:14 PM
72442clone
Jul 25, 2011 10:40 AM
