Exhaust valve hardened seats depth
How deep can the machinist cut the heads for the hardened seats without hitting the water jacket on a set of #6 cylinder heads?
I got the .219 Manley hardened seats that are compatible with the stock exhaust valves (which I am using).
I just want to make sure that the machinist knows not to go to far thinking he is working with Chevy heads which are thicker (so I am told).
d1
d1
My machine shop used to cut the hole .200" deep, and just trim off the top .020 with a cutter to keep as much material as possible in the head. They say that .220" is ok, but if there was core shift of any sort, or a casting issue with that pour it could lead to issues later on. Better to be safe, I like that train of thought.
Did you ever get any valves?
I have not had a chance to look, I am sure I have some around the garage, at least in another set of heads.
Jim
Jim
Jim
Jim
I did get valves, but thanks for asking.
d1
Excuse the thread jump --am in fact trying to add to the info.I have a set of BBO B heads that I was contemplating doing the same --ie installing hardened seats .Any ideas on the depth of cut here to "be safe"
thanks mike
thanks mike
Texas Jim
November 23rd, 2009 08:44 AM
