Exhaust manifold gaskets
Old Aug 2, 2008 | 01:07 AM
Redog's Avatar
I don't need them on a 350, it that correct?
The gasket in there are warped and causing a leak. I was going to pull them out
Old Aug 2, 2008 | 01:31 AM
88 coupe's Avatar
Junior Member
If you don't use gaskets, they can't leak.
You will need to to have the flanges surfaced by your machinist.
Norm
Old Aug 2, 2008 | 05:49 AM
Redog's Avatar
Just trying to hold on long enough to get headers.
Found a set that should fit the 80's B body
I got to get rid of the stock 307 exhaust manifolds
Old Aug 2, 2008 | 08:56 AM
BILL DEMMER's Avatar
Just the facts...
Norm
and possibly the head surface where they mount.
bill
Old Aug 2, 2008 | 10:14 AM
I don't know what manifolds you're running, but be aware that the tubular manifolds used on the later 307s DO require gaskets. Also, these gaskets have different port sizes than all other Olds exhaust gaskets.
Old Aug 3, 2008 | 06:19 PM
Redog's Avatar
No these are the cast iron ones.
I got lucky. They changed them 1/2 way thoght the 85 model year and I got the old ones.
If I remember correctly they are 14/17's
ChrisM
Mar 19, 2015 08:57 AM
76oldswarrior
Sep 1, 2012 05:59 AM
sixty9olds
Jun 20, 2012 09:37 AM
trackz man
Mar 9, 2011 01:53 PM
rustyold66
Sep 28, 2008 07:45 AM
