Exhaust help
Old December 2nd, 2010, 10:05 AM
  #41
STOP call'n it a Chevelle
arodenhiser's Avatar
Originally Posted by jasm8
I'm going to be running a re-built rocket 350 with a muncie 4-speed & headers, and my question is are there going to be any special difficulties/modifications that will need to be done (aside from the ones listed above) for headers with the manual transmission? Or is it pretty much the same as doing the automatic? Thanks!
There is supposed to an issue with the clutch linkage, depending on which manufacturer's headers you buy. Hooker gives these instructions for the modifactions. It does not look too difficult, have a look at the second page. I have never done it myself since I have a 350th.
http://www.jegs.com/InstallationInst...0/520-3901.pdf
Adam
arodenhiser is offline
Old December 2nd, 2010, 12:19 PM
  #42
507OLDS's Avatar
The only issue you might have is one of the header pipes coming in contact with the z-bar.I know the old Doug Thorley's will clear,and some of the Hooker's will.
I have also been told that if you use a Chevelle z-bar in a Cutlass,it will clear the headers better,but I have never tried this,so I don't know.I did modify one of my z-bars,by moving the fork arm over towards the center,to clear a large set of pipes before.
507OLDS is offline
Old December 3rd, 2010, 02:52 AM
  #43
Yellowstatue's Avatar
When you install the left side, you must do the header, starter and cross shaft at the same time it really helps to have three hands and a fourth to start the bolts...
Yellowstatue is offline
atkinsom
May 29th, 2013 06:39 PM
cutlassclay
May 11th, 2012 06:31 AM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
MJAKS462
April 15th, 2010 02:34 PM
Quick Reply: Exhaust help
