engine woes
Old Mar 12, 2015 | 10:30 PM
  #41
80 Rocket's Avatar
Originally Posted by speakfordadead
Looking for validation??? Okay. I'll bite....
My comment is null and void and you are correct, this was an exercise in futility, I should keep my mouth shut and speak only when spoken too.....
Phew, I'm glad we see eye to eye now. For a second, I thought you thought excessisive compression with an iron head on pump gas wasn't a problem.
I like your style my friend, stick around here.
Old Mar 13, 2015 | 04:02 AM
  #42
Sampson's Avatar
I woke @ 3:00 this morning with the 2 points being made in this thread going around in my head.
Timing problem is mute because of the compression issue.
Get the engine dialed in before you address the compression issue.
I came to the conclusion that it is a "chicken or the egg thing"
He can address the compression and install new heads. That will do nothing to reveal what is causing the unsteady timing. How frustrating will it be when he takes it for the first test drive he hears the pinging because he didn't address the timing issue. Both need to be taken care of.
Old Mar 13, 2015 | 06:23 PM
  #43
I'm wondering what the total timing is set to, both with vacuum advance and without. Is it pinging under both light throttle and wot? I understand about the compression, but the voices are leaning towards a cam timing or distributor issue.
Does the engine run smooth or does it shake at idle? When you raise the idle manually is it smooth or does it chug up. What I'm getting at is it possible the cam was not setup correctly?
Old Mar 13, 2015 | 07:50 PM
  #44
olds 307 and 403's Avatar
Out of Line, Everytime😉
He should run it as little as possible or he will beat the bearings out of it.
Old Mar 13, 2015 | 08:18 PM
  #45
oldolds88's Avatar
easy compression check,find someone with one of these..
http://store.katechengines.com/whist...ster-p174.aspx
any race tracks near where you are?
Old Mar 13, 2015 | 10:25 PM
  #46
speakfordadead's Avatar
I agree....bubble that thing and see where it comes in..... there is no need to beat the bearings.... it's most accurate when it is cold
Old Mar 14, 2015 | 05:26 AM
  #47
He should not get any detonation just idling it unless the cam is setup wrong or his timing is way out of whack.
Old Mar 14, 2015 | 05:54 AM
  #48
cutlassefi's Avatar
Does the engine run smooth or does it shake at idle? When you raise the idle manual is it smooth or does it chug up.
Ok here's where the misnomers come in.
I have stood right in front of, on the side of, in the same room as an Olds that had too much timing in it, yet it didn't "ping" once, not once. How do I know? Simple, when you lose significant hp on one pull vs another, with the only change being the timing, then regaining that lost power retarding the timing back to square one, then you know.
I've said this before, detonation is called the silent killer. There's a reason for that, cuz it's true.
Verify your cranking compression at operating temp, not cold, and go from there.
Thank you.
Old Mar 14, 2015 | 06:16 AM
  #49
Sampson's Avatar
[QUOTE=cutlassefi;
Thank you.[/QUOTE]
What would you expect the maximum cranking compression range to be in an engine without detonation?
Old Mar 14, 2015 | 08:53 AM
  #50
I'm trying to understand the question... 7.5 to 15?? Help me here.....
Old Mar 14, 2015 | 10:21 AM
  #51
80 Rocket's Avatar
With iron heads and pump gas, somewhere around 180.....and that is with the engine up to temp. I believe I read in one of David Vizards books that he says 200-220. I don't know how he does that.
Old Mar 14, 2015 | 10:25 AM
  #52
80 Rocket's Avatar
He's talking about using a compression tester gauge that reads the cranking compression in an engine.
http://www.eastwood.com/gas-comp-tester.html?fee=7&fep=48094?fee=5&fep=4990&SRCCODE =1SE1528&creative=5461472965&device=c&matchtype={M atchType}
Old Mar 14, 2015 | 11:27 AM
  #53
I see, he is asking about PSI... got it.... he wants to know the psi range of the compression.....
165-220 rings being seated in is a variable though. can lower the pressure somewhat.
Old Mar 14, 2015 | 11:31 AM
  #54
http://www.wallaceracing.com/dynamic-cr.php
found this one on the net
Old Mar 14, 2015 | 01:58 PM
  #55
Thank you.
Originally Posted by PhilBlack
I cannot run my car for fear of blowing the motor. Pinging/detonation is scaring me. Engine is a 1971 olds 350, .30 over. Block zero decked. #7 iron Heads milled and polished. Flat top pistons. 10.1:1 compression ratio(calculated). I have felpro head gaskets. Cam is a Comp XE268H. Plugs are AC Delco 45s. Stock Distributor with Pertronix installed under the cap - stock springs/weights. I tried re-curving but was not happy with the results. Stock coil. Timing is dialed down to 8 initial. 1000 miles since built. Pings so bad I can't drive it. Even on 93 octane it sounds like an army shaking spray paint cans. Suggestions?
I'm try to figure out what he's trying to say for the initial reason he posted the question. Apparently his issue is not silent.
Old Mar 16, 2015 | 07:59 PM
  #56
PhilBlack's Avatar
I applaud your debate skills. You are a gentleman and scholar.
Again, who cc'd the heads? What heads were on it before the Machinist decked the block?
He should check his work. He should not waste a set of head gaskets et al until he has. That's where I am coming from. You can't establish the true problem until you have eliminated all other possibilities. I wouldn't tear into that fresh engine until I could confidently say I did everything right. JMHO
Machine shop cc'd the heads. I have been through sparkplug options, leaned out and richened the a/f mixture, new carb, ignition timing, no vacuum advance, jacked with every combo of distributor weights and springs, cam is straight up but straight up for this grind in 4 deg. advanced. I'm not as smart as you all but am pretty thorough. Head gaskets are cheap. It's my time that has been getting expensive.
Old Mar 16, 2015 | 08:01 PM
  #57
PhilBlack's Avatar
Initial reason for posting; looking for some help in making this enjoyable to drive without worry of grenading.
Old Mar 16, 2015 | 08:03 PM
  #58
When you remove the heads, cc them and measure the deck height yourself, so that you know where you stand.
  #59
PhilBlack's Avatar
No detonation at idle. Under load, accelerating. Stable RPM, no problem.....that I can hear.
Old Mar 16, 2015 | 09:04 PM
  #60
Have you tried driving it with the vacuum advance disconnected and plugged?
Old Mar 16, 2015 | 09:40 PM
  #61
80 Rocket's Avatar
Here is another option that may allow you to keep the heads you have. Cometic offers multi layer steel head gasket that are .060" thick. They are pricey (around $200 for the pair) but they are reusable. I have had the heads off my dragster motor about 3 times now with the same gaskets.
Step number 2 would be to polish your combustion chambers in the heads. This will net you an additional 2-3ccs, and will also help reduce hot spots in your combustion chamber, which can ward off detonation or pre-ignition. It's like a win-win there.
These two thing will bring you down to around 10:1 (or slightly less) depending on where your combustion chambers size out cc-wise. And you get to keep your freshly worked over heads.
Old Mar 17, 2015 | 05:30 AM
  #62
Originally Posted by 80 Rocket
Here is another option that may allow you to keep the heads you have...
Good idea.
Old Mar 17, 2015 | 08:02 AM
  #63
PhilBlack's Avatar
oldcutlass - Yes. I am actually not running any vacuum advance currently.
80 Rocket - Heads were previously polished. Milling brought the CC back down.
I have another set of 7a heads - unmilled, I could polish and try.
Old Mar 17, 2015 | 11:30 AM
  #64
80 Rocket's Avatar
Have you ran a compression check on this engine yet? I am curious to see where it comes out at. I'm guessing it's gonna be around 240 when warmed up.
Do you know how much they milled your current heads? It sounds like they would have had to take off about .040"-.060" to end up at 64ccs after polishing the combustion chambers.
How did your intake fit on the engine when you put it together? Did the mating surfaces have to be milled or slotted bolt holes?
Old Mar 17, 2015 | 01:53 PM
  #65
captjim's Avatar
Dynamic compression is a tricky thing, affected by a variety of factors (intake volume, head flow, ring seal, and on and on). I agree with Don, IMO, cranking compression should be 180 tops for a street car unless you are a VERY good tuner.
Also, no engine will detonate at idle, if it did, it would not start when at operating temperature.
Old Mar 17, 2015 | 07:56 PM
  #66
Is someone near him with a compression tester??? I can mail you one of my spares if you promise to mail it back!!!
Old Mar 18, 2015 | 05:31 PM
  #67
PhilBlack's Avatar
I have a compression tester. Need time to check. This weekend is my best option. I appreciate all the input. Please stay tuned....pun intended.
Old Mar 19, 2015 | 06:44 AM
  #68
Cometic gaskets can be ordered up to .120" thick, correct? I figure I need around .100" thick on my next build.
Old Mar 21, 2015 | 03:13 PM
  #69
PhilBlack's Avatar
compression test results
1 = 179
2=180
3=178
4=154 / 152. *****
5=198 / 198*****
6= 185
7=180
8=182.
Old Mar 21, 2015 | 04:05 PM
  #70
80 Rocket's Avatar
1 = 179
2=180
3=178
4=154 / 152. *****
5=198 / 198*****
6= 185
7=180
8=182.
Those figures are with it warmed up?
Something is amiss there with a 152 and 198.
For reference, my dragster motor was pumping 180 across the board with a tired 385" small block Chevy. The motor is 11:1 compression.
Old Mar 21, 2015 | 04:08 PM
  #71
PhilBlack's Avatar
Yes. Warmed up. Ran outta time this afternoon. Going to wet 4 with some transmission fluid to rule out rings. Suspicion is valved though. That bank seemed to run hot.
Old Mar 21, 2015 | 04:32 PM
  #72
captjim's Avatar
Did you do it with the ignition disabled and throttle wide open?
Old Mar 21, 2015 | 04:41 PM
  #73
PhilBlack's Avatar
Yes.
Old Mar 23, 2015 | 08:16 AM
  #74
How many miles on this build? One high and one low, hmm. I am wondering if the rings are properly seated yet? Did you try a spark plug like a NGK 5670-8? I would try atf in all the cylinders. The Cometic head gaskets can be ordered to .140" thick but $50 more per gasket above .051" thickness. Over .100" thick is another $100 each.
Old Mar 23, 2015 | 08:54 AM
  #75
PhilBlack's Avatar
Maybe 1000 miles on the build. Haven't really been able to run it due to pinging.
Cometic prices - gaskets must be made of gold!
Old Mar 23, 2015 | 02:59 PM
  #76
If everything breaks in the way it should, all cylinders should end up around 200. Cometic's are expensive but the best gaskets you can buy.
Old Mar 23, 2015 | 07:14 PM
  #77
PhilBlack's Avatar
I am guessing, based on the latest comments, I should probably yank this turd and find a different builder.
Old Mar 23, 2015 | 07:54 PM
  #78
80 Rocket's Avatar
Who determined what compression ratio this engine would be? And how did they arrive at that number?
Old Mar 23, 2015 | 08:04 PM
  #79
PhilBlack's Avatar
I told the shop 10:1 over 6 years ago. Shop calculated compression to 10.1:1. They cc'd the heads after milling. They built the bottom end. I assembled top end. Have been battling a tune ever since. I'm going to drive this motor till it blows. Not enjoying the car as I should. I have the numbers matching motor on a stand. I will put a stock build on it - a stock grind cam, original 4 bbl and drive it. Thank you all for your help and input.
Old Mar 24, 2015 | 04:02 AM
  #80
Sampson's Avatar
That sure sucks. You have a lot of money and time invested in your build. You will have a lot more invested in rebuilding the new one. I would consider trying to get the rings seated and investing in the Cometic Gaskets. Good luck with whichever route you choose.
