View Poll Results: Engine change from a diesel to gas engine
How to wire the gas engine from a diesel engine
0%
I change an engine from a Pontiac 350 engine diesel to a Oldsmobile 350 gas I need help
100.00%
Voters: 1. You may not vote on this poll
Engine change
Old Apr 10, 2021 | 04:02 PM
Voma's Avatar
Engine change
I have a 1980 Pontiac Bonneville diesel and I bought a 1977 Oldsmobile 350 gas engine. I'm pulling the Oldsmobile engine in the Pontiac is there a book that can tell me how to hook up wiring and vacuum lines to hook up to the Oldsmobile engine. The wiring and the vacuum lines on the Pontiac Bonneville diesel not the same as the Oldsmobile engine. Please I need some help to connect all the vacuum lines the wiring
Old Apr 10, 2021 | 04:36 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I doubt it. It should not really be that difficult if you take your time. It would probably be a good idea to label wires as you take them off the diesel. You may have to make some of them shorter or longer.
Old Apr 10, 2021 | 04:55 PM
The Oldsmobile-sourced diesel in your car is externally identical to the Olds gas 350. One thing that you'll find is that the diesel cars have the driver side motor mount and frame pad relocated forward to clear the larger diesel starter. You can move that pad back to the gas engine location, but it's kind of a pain to reach the bolts with the lower control arm in place, If you chose to use it as-is, then be sure to transfer the adapter plate on the side of the diesel block to the gas block so the motor mount will match up.
Old Apr 10, 2021 | 04:56 PM
Voma's Avatar
Engine change
I'm looking for repair book for 1977 Oldsmobile 350 rocket engine
Old Apr 10, 2021 | 04:57 PM
Voma's Avatar
Engine change
Old Apr 10, 2021 | 05:00 PM
There is no engine repair manual, the engine information is in the larger Chassis Service Manual.
Old Apr 10, 2021 | 05:20 PM
Voma's Avatar
Engine swap
Thanks for the information about engine repair book do you know who has the book that you refer me to I've tried looking for something like that. I can't seem to find that book for a 1977 Oldsmobile 350 rocket
Old Apr 10, 2021 | 05:22 PM
Voma's Avatar
Engine swap
I am also a Vietnam vet 69 to 71 thanks for your service buddy
Old Apr 10, 2021 | 05:24 PM
There are currently 20 of them on ebay, with prices ranging from $5.00 to $28.00. Type 1977 oldsmobile chassis service manual into the ebay search box.
Old Apr 10, 2021 | 07:25 PM
redoldsman's Avatar
Thanks Voma. I was at DaNang in the USAF from August 69 to August 70. Joe usually mentions it but DO NOT buy a reproduction or a CD version. Get an original with a few greasy fingerprints on it. As you can see prices vary.
pmgriphone
Oct 18, 2018 08:36 AM
rustbukt307
Sep 7, 2017 01:55 AM
victorMhernandez
Jul 7, 2012 12:44 PM
BruceC
Sep 8, 2011 10:07 PM
