Edelbrock RPM Intake
Old August 7th, 2012, 09:51 PM
Mark30's Avatar
I was wondering if the RPM intake would be too much for a 1969 350 4 barrel?
The engine is stock but will have long tube headers. It is the 10.25 comp engine.
Mark30 is offline
Old August 7th, 2012, 10:45 PM
Kickin' It Oldschool
bdub217's Avatar
olds 350? chebby 350? =/ need more info please!
Is this a stock motor? Crate?
thanks
based on the little info you gave me here's something to read.
Performer RPM Intake by EDELBROCK
TAKEN FROM EDELBROCK WEBSITE:
Designed for 330-350-403 c.i.d. Oldsmobiles and 1980-1/2 to 1985 307 c.i.d. engines with 5A heads (casting #3317). The Performer RPM Olds manifold is a high-rise, dual-plane design with 180° firing order engineered for maximum top-end horsepower while maintaining throttle response. Port flange has extra material above the runner for use with cast iron 455 heads and Edelbrock Performer RPM heads #60519. Has clearance for HEI distributor. Carb pad accepts square-bore carbs without adapters.
Installation Notes: Recommended intake gasket: Fel-Pro #MS96027. No provision for OEM choke. Will not clear hood on 403 Olds, Firebird/TA. OEM carb requires conversion to electric/manual choke. Manifold Height: 2" taller than stock A-4.80", B-5.80"; Carb pad height: 5.30" see A/B Measurements. Port exit dimensions: 1.22" x 1.86".
like I said I can't be much help nor with others without some more information on the motor.
bdub217 is offline
Old August 7th, 2012, 11:44 PM
DoubleV's Avatar
Being that this is an Olds site, I would assume he's refering to an Olds engine and he did mention it's stock with headers.
Mark30, you're going to get mixed responses as to whether an RPM intake would be better than a regular Performer ( or stock ), so be prepared. There are going to be some that will swear up and down the RPM won't do you any good ( or even hurt performance! ), but then others will swear it WILL make a difference, so it's going to be hard to make a decision based off the responses you're going to get.
From my own research on this, I have read of one guy who says the RPM intake didn't improve his ET's and was less responsive on the street. I have also read of a guy who was able to consistantly spin his tires up to a higher rpm than before the swap ( implying noticably more power ) and another guy who's ET's DID improve with one ( even on a stock 307 which he tried it on too! ). These were people with very mild/stock/stockish 350's.
I can tell you that when I put the RPM intake on MY very mild, dinky cammed 350, I may have noticed a LITTLE boost up top but I most certainly did NOT lose anything anywhere in the RPM range.
On another note, it is unlikely your CR is 10.25. Those engines are usually much lower than advertised ( more like highish 9's ).
So IMO, if you're planning on a bigger than the junk stocker cam down the road, I would go with the RPM all the way. If I wasn't going to touch the motor at all, then it's kind of a toss-up but maybe leaning toward the regular Performer intake ( because it's readily available used for cheap and it's lighter than the stocker ). Either way, I wouldn't expect too much from an intake swap unless you're planning on some other upgrades ( like bigger cam and maybe some head work ).
DoubleV is offline
Old August 7th, 2012, 11:57 PM
bdub217's Avatar
my fault! got caught up in my response that i forgot about it being stock, just wanted more info as to what car and what carb what heads etc Bad habit of not reading everything in it's entirety sometimes.......glad I'm not that way when I work on stuffs =0
He didn't say anything about racing and what not so that would mean the intake he's asking about would be okay.
bdub217 is offline
Old August 8th, 2012, 05:00 AM
captjim's Avatar
I did this several years ago,
http://www.realoldspower.com/phpBB2/...performer++rpm
However, I had a 9 to 1 355 with a 210/216 cam and 3.42 gears. It was right on the line. If you have the 6 cc pistons, the RPM is probably the better choice. If it was me, I would upgrade the came while you have it apart. Stock is very mild, somewhere around .400/194.
captjim is offline
Old August 8th, 2012, 07:09 AM
Mark30's Avatar
The engine is a stock oldsmobile engine. I only quoted the compression ratio as thats all I have to go by and I wanted to make it clear it was the different 350.
As for what I am looking to do with the car, I am looking for a strictly street engine. I think I would prefer a performer but I have found someone selling a RPM for a very low price.
I currently own a Holley street dominator but I don't want to use it strictly because of its looks. I like the dual plane as they look more stock.
As for a cam, I was thinking of getting a W-31 style cam, but to be honest, I haven't really researched much for it.
Currently my car has a 350 transmission with a peg leg 2:56. I am looking to swap that for a set of 3:73 with a 200r4 to keep the same final ratio.
Mark30 is offline
Old August 12th, 2012, 10:19 PM
ah64pilot's Avatar
Doesn't get any more definitive than a dyno so here ya go...Performer beats RPM Air Gap:
https://classicoldsmobile.com/forums...parison-4.html
ah64pilot is offline
Old August 13th, 2012, 05:08 AM
The only real difference is the the range in RPM and carb pad height.. If you had a little higher stall converter and a cam that will function with your setup, then the RPM manifold will perform fine.
oldcutlass is offline
Old August 13th, 2012, 05:13 AM
cutlassefi's Avatar
That's on a big block, not the same comparison. The regular performer for a small block is way smaller than the rpm both in runner size and plenum.
A big block performer actually has a larger plenum than the rpm does, that's why the big difference when using a carb that's essentially too small.
Use the RPM, you won't be sorry.
cutlassefi is offline
Old August 13th, 2012, 09:33 AM
LX89mustang's Avatar
That test was in no way accurate for 2 big reasons .
1. The dyno seemed to be malfunctioning due to the rpm reading on the sheet.
2. The motor had too small of a carb to start with .
Also , as Cutlassefi stated , that test was on a 455 .
LX89mustang is offline
Old August 13th, 2012, 11:43 AM
bccan's Avatar
I can't believe it - A thread w/ no nasty differences of opinion! Yet. We swapped RPM on to the red car from std Performer. 9:1 350, 202/212 x .5xx HR, 1 5/8" headers, 2 1/2" x pipe, 200-4R, 3.08, '68 OAI setup. Didn't hurt the low end at all, arguably helped top end. Carb did not need recalibrating, just an idle screw adjustment. I'm not sure if 1/4 mile performance changed or not. It runs 14.3 @ 96 like clockwork but I don't remember what it ran prior to that.
My opinion would be to run either one, you can't lose. Performer might be better presently but w/ some more gear & cam I would RPM it.
bccan is offline
Old August 13th, 2012, 11:59 AM
Chevy budget Olds powered
coppercutlass's Avatar
I guess it comes down to what your future plans hold. I would go rpm for the fact that if he decides to build up that 350 down the road he can re use the intake on a future build.
coppercutlass is offline
Old August 13th, 2012, 02:15 PM
ah64pilot's Avatar
Yeah, it was late and I was skipping around. Totally missed that this was a small block. My bad.
StickW31
September 9th, 2012 06:57 AM
85cutlass6.6
August 4th, 2011 07:34 AM
70Cutlass_408
June 16th, 2011 11:48 AM
oldzy
December 13th, 2010 09:06 PM
Quick Reply: Edelbrock RPM Intake
