Edelbrock electric choke issues
Old Oct 12, 2012 | 10:12 AM
yeahbuddy's Avatar
I have a Edelbrock 650CFM on my 350 Rocket. In the morning after the car has been sitting for 12+ hours I just need to tap the gas twice before starting and the choke it set. It revs higher until I tap the gas to go back to normal idle speeds. My issue is after my first drive every morning (usually about 10 miles to work), I park my car for about 4 hours until its my lunch break. When I start it for the 2nd time of the day since its warmer out the choke does not set and it dies instantly after starting unless I lightly hold down the gas pedal. I find myself quickly throwing it into drive and hitting the gas and then it idles perfectly fine. How do I set the choke when its warmer out? I press the pedal down before starting but it doesnt do anything different.
Old Oct 12, 2012 | 10:31 AM
Either rotate the choke spring housing so that it is more closed when slightly warm or just pump the pedal a few times before starting.
Old Oct 12, 2012 | 10:47 AM
yeahbuddy's Avatar
Eric as I mentioned, pumping the pedal after parking makes no difference. How exactly do I rotate the spring
Old Oct 12, 2012 | 11:33 AM
You have loosen the three torx head screws around the plastic housing.
Old Oct 12, 2012 | 11:49 AM
yeahbuddy's Avatar
Then rotate to the right or left? Remove the whole cap?
Old Oct 12, 2012 | 12:06 PM
Do not remove the cap and turn it 2 notches to the right.
Old Oct 12, 2012 | 01:07 PM
yeahbuddy's Avatar
That did the trick. What would I do without you guys.
Old Oct 12, 2012 | 01:17 PM
Glad it worked out.
240 Gordy
Oct 11, 2020 10:04 AM
cut123
Mar 27, 2013 07:55 PM
mp71conv
Jan 21, 2009 02:28 PM
woodie582
Nov 7, 2008 01:07 PM
justinj
Nov 5, 2008 06:07 PM
