Edelbrock avs2 1906 idling way high
Old Mar 5, 2026 | 03:53 PM
Flashflood's Avatar
I've got an edelbrock avs2 1906 carburetor on my 403 olds and it is idling at like 3000 rpm immediately. The fast idle screw is all the way out and not changing a thing. I can't kick it down. Choke is plugged in to a good 12v. All vacuum ports are blocked off or connected. I'm about to switch back over to a Rochester. My last step is to plug in the brake booster but I doubt it's going to make a difference.
Old Mar 5, 2026 | 05:54 PM
letitsnow's Avatar
It ran ok before adding the Edelbrock? I ask because I was sure that my 1406 was junk because it wouldn't idle down, then I put it on a different motor and it runs great. My intake gaskets were leaking...
Old Mar 5, 2026 | 06:07 PM
Flashflood's Avatar
honestly don't know only carb that's been on this thing. This is a freshly rebuilt engine only started a couple weeks ago. I'm going to pop the edelbrock off there this weekend and take a look at the carb gasket. Replace it then I may see how my quadrajet runs it. If it runs the same I know somethings up.
Old Mar 5, 2026 | 06:47 PM
Disconnect the throttle linkage from the carb and see if it idles down. There are 2 adjustments for idle speed, 1 for the choke and 1 for curb idle. Make sure any open vacuum ports are capped.
Old Mar 5, 2026 | 07:38 PM
Also, not a bad idea to read your vacuum w/ a vacuum gauge to obtain a baseline just so you know what you're working with.
Old Mar 6, 2026 | 04:18 AM
BillK's Avatar
What intake manifold is it ? If it is an Edelbrock spread bore manifold you might have to use the thin plate under the carb to avoid a vacuum leak.
https://www.edelbrock.com/square-bor...olds-2732.html
mownhoj
Mar 8, 2026 01:39 PM
67442nut
Sep 3, 2014 11:58 AM
DocAS
Jul 28, 2014 09:55 PM
377rick
Jul 24, 2014 06:35 AM
'S'tuff1979
Apr 28, 2012 09:44 AM
