Edelbrock avs2 1906 idling way high
I've got an edelbrock avs2 1906 carburetor on my 403 olds and it is idling at like 3000 rpm immediately. The fast idle screw is all the way out and not changing a thing. I can't kick it down. Choke is plugged in to a good 12v. All vacuum ports are blocked off or connected. I'm about to switch back over to a Rochester. My last step is to plug in the brake booster but I doubt it's going to make a difference.
honestly don't know only carb that's been on this thing. This is a freshly rebuilt engine only started a couple weeks ago. I'm going to pop the edelbrock off there this weekend and take a look at the carb gasket. Replace it then I may see how my quadrajet runs it. If it runs the same I know somethings up.
What intake manifold is it ? If it is an Edelbrock spread bore manifold you might have to use the thin plate under the carb to avoid a vacuum leak.
https://www.edelbrock.com/square-bor...olds-2732.html
