edebrock peformer or performer rpm?
#41
Take your time. Ask whatever questions you need to. As you can see, there are several of us that can answer them .
Everything will happen 4° later, most importantly the closing of the intake valve, while the piston is moving up in the cylinder. This delay. allows less time/distance for the fuel/air mixture to be compressed.
Norm
Norm
#42
Yeah, all the way down to 9.15, wow!! Still waaaaaay too high. Mp71conv, you either need another cam or lower static compression, and that means different heads or pistons. At what stage are you in this build?
#43
........ On another matter, someone will have to convince me that these 2 statements made by Norm in this thread do not constitute internet bulling and how they encourage and promote the exchange of ideas in a fun, friendly environment.
"If you dare question that opinion, I will launch the "mother of all personal attacks" which will get you "banned" from this site."
" Wireman: If you cannot stand the heat, stay out of the kitchen."
Norm
#44
Engine still at machine shop. I have the cam already.
Now Im confused. you said 9.15 is still too high. I thought i wouldnt have a problem till 10.5?
Looking at the factory specs. The duration is low like this cam but the lift is much lower.
and all the pre 71 pistons were flat tops.
#46
" and all the pre 71 pistons were flat tops."
This is incorrect, most had a small dish in them.
#48
9.15 is probably closer to "ideal" than 10, but either can work well, in most instances.
Your choice depends on what you want to accomplish. For most non competition applications, 9 to 9.5:1 CR with (iron heads) are best for use with pump gas.
My latest 468 is 11.9:1 and it runs fine on California's 91 octane, but unlike the "experts" I do not suggest that anyone do the same, unless they are, or know, a competent tuner.
Not so. You should be looking at specs, not years or manufacturers.
Has your shop verified the heads/block dimensions yet? Particular interest, is the deck height as it is a factor in the choice of pistons?
Norm
Norm
#49
I just realized that I used the wrong cam in my calculations. He did not give a part #, just said 219 @ .050. I thought he was referring to the intake. But from his other thread I see he meant the 60801 which is 213 @ .050 on the intake. Now he is REALLY too small on the cam.
#50
Not what you said. We can assume it to be a clerical error.
Your opinion?
According to the following:
Which is it?
Norm
#52
Ok I am going to see if they wiil take the cam back for another ( it is unopened so that should not be a problem).
Ill look at there stock performance ones. They have one that is 232int 232 ex.
480 lift int 480 lift ex. 113 lsa
#54
http://www.oldspower.com/vb/showthread.php?t=36717
Norm, I'm done taking your bait, have a lovely day there in SoCal!
#55
........ I am including a link that I wrote explaining how I go about a project http://www.oldspower.com/vb/showthread.php?t=36717 ........
As always, I am ready and able to answer any, and all, questions regarding anything I post.
It is not a small stretch, from a simple question to "bait", but the statement itself tends to reinforce my opinion, regarding BS artists.
Norm
#56
Cam moron speaks out
Hey guys he's starting a new thread "Let's start over"
Since I am a cam moron, I think I should add my 2 cents here.
Wouldn't it be easier/better for him to start anew w/o purchasing a cam and first get his shop to help him measure everything to see what he's got. I mean the car could [or could not have] had some machine work done to it.
Just MHO
first things first
Gather the facts.
Isn't that what you guys would do before you made any decision?
Sorry to butt in
Just MHO
first things first
Gather the facts.
Sorry to butt in
#57
Did I not just state that in my last post?
Originally Posted by captjim
........ Call a professional builder/vendor and get their recommendation on a cam ........
What a novel approach. Most people would call a cam grinder for advice on a cam choice.
The reason I like to use a builder is that they have dealt with the end product and a competent one will have a very good idea of what has worked well in the past. Most have proven combos that they like, ones that they know will perform well in a given circumstance. In most cases, the builder will call his own grinder, get one ground to the specs that they like for the application. By dealing with the builder, you can then go back to him with questions or advice, if needed.
........ Measure everything, then determine the true compression ratio of this engine ........
What good would that do, if the pistons are to be replaced?
Because it might be better to replace the cam, especially if he intends on a gear and converter swap. But in reality, you don't want an answer, you just want to prolong the nonsense.
I'm done taking your bait ........
You can call me a "BS artist", that's fine. I build and race Oldsmobiles, I work at a machine shop part time and have access to a couple of really smart guys. I come on these forums to have fun, learn new things, and try to help other guys, if I can. The same cannot be said for yourself. You take the fun out of it and suck the life from this board, it really is too bad.
#58
But many DYIs prefer to shoot themselves in the foot" by telling the shop what to do, instead of taking advantage of the experience that is looking them in the eye.
I am working (as we speak) on a new thread that will explain what captjim (and all his "credentials") cannot.
Norm
#59
Jim and Jamesbo, getting the specs hammered out first is a good idea.
Also, Capt Jim.
To properly quote yourself or another poster on the board, once you hit the quote button you must leave the html info in the brackets at the beginning of the text box, then leave the wording that you wish to keep, and finish the last line of the text box with: [/QUOTE]
visual example:
[QUOTEcaptjim######] Texttextquotequote [/QUOTE]
Hope this helps.
Also, Capt Jim.
visual example:
Hope this helps.
#61
Sorry, I spend my time actually working on cars, and have not mastered the internet or computers. My bad.
#62
Dang..... I'm just trying to be helpful, not a jerk. Proper quotes will make your information more easily understood, thus getting your valid points across more efficiently.
#63
Yes you did.
Did my reply go over your head?
It did remind me of another that I missed:
Went right over your head, didn't it.
"If you dare question that opinion, I will launch the "mother of all personal attacks" which will get you "banned" from this site." ........
#64
Like any "BS artist" he does not want to be clear. Proper coding would make it too easy everyone to catch on to his childish games, and it would leave that pesky blue arrow, so everyone would be able to read the post, in its original context.
His rude reply is just another tool used by a "BS artist" in any similar situation.
Norm
#65
Mine do not need any work, because I do it right the first time.
That would be why you have not mastered your "ignore button"? And why you cannot answer simple questions about your own statements?
But you do seem to have plenty of time to flame anyone (and/or trash an entire thread) who asks a question that you cannot answer.
Isn't it interesting that I am ready and willing (if not eager) to answer any and all questions pertaining to my own posts.
How can it be, that, with few exceptions, my statements are never challenged.
Could it be that (in spite of my lack of "credentials" I might have reasonable cause to challenge yours? Maybe, that you have based your "opinion" in on some misinformation you have acquired? No, that cannot be possible.
Or did it occur to you, that I might be looking for some knowledge you have that I do not have?
Also not possible, because, according to you, and your minions, I already know everything there is to know, and my only purpose here, is to torture captjim.
Norm
Norm
#66
Found an interesting statement, while working on my new thread.
Isn't 9.8 getting dangerously close to 10:1?
Norm
........ Let's say I want a SBO premium octane weekend warrior, but I want it to idle and have good street manners. So, I am going to target a 9.7-9.8 Cr ........
Norm
#68
Looks like it is. I'll know, when I have time to read all of it.
Good to see you are searching on sites other than forums. Shows you are one who can think for himself.
Norm
Norm
#69
That article was a link I provided him in post # 37 of this thread, glad you found it useful. Hope it helps explain why I think the cam would be too small for your application.
#70
Well I did not know all the points to look at when getting a cam.
I learn something new all the time.
But it does seem to be that it is not just the duration but
the degree after bottom center that the intake closes.
And the cam is at the mid 30's. That is not good.
And it make sense to me. so off to get a different one.
Thanks to all
I will keep everone up to date on what happens.
Thanks to all
#71
Thanks to all
Thanks to all
#72
Thanks to all
Thanks to all
Don't we all? That is part of the fun, when we stop learning, it isn't nearly as exciting.
#73
Maybe Jokers69 will be able to answer it for us.
Adios..
#74
In other words, you cannot answer the question?
Because I asked a simple question?
A question that captjim would, trash an entire thread, just to avoid answering?
Norm
Norm
#76
Call Rocket Racing or Smitty... or go directly to Harold.
#79
and, no, I cannot answer you question, so am I thrown off the island *******?
