Ebay stainless 350 headers
I know there was a thread talking about these headers but for some reason I cant find it. Has anyone bought and installed the headers that are sold on ebay for about 180.00? I was thinking of purchasing these and an H pipe flowmaster exhaust kit. Heres the link to the headers.
http://www.ebay.com/itm/170879970963...ht_2944wt_1362
any help or suggestions will be appreciated.
Leche
Leche
small and big block
Ive never had a 455 but from what I have read the blocks are similar or the same...but the 455 is taller is some regard so they actually use the same header.....im sure im off a bit so everyone don't rip me apart!
leche
leche
I purchased a set of these a couple of years back. Yes, the picture looks nice. However, they don't show the sharp kinks in the bends behind the tubes. A restriction and hot spot. I emailed them back and they told me that if I didn't like them to just send them back. I pay the shipping from Cal. to Michigan.
Anyways, I am running them for the time being. They do have thick flanges and clear everything (starter, oil filter) nicely. They were a breeze to put in from underneath. The #6 rear bolt was a real PITA and I had to hog it out a little to be able to get the bolt in with a short one. Some of the others needed to be honed a little to line up. As I learned again, You get what you pay for. For a low budget and just street, I guess these are fine. At least they won't rust! Oh, and I run a 455.
Leche
Leche
Stanley
There are 2 good things about these cheapy's. 1 They clear the starter and large oil filter nice. 2 They tuck up real nice underneath compared to my old Heddman's that hung really low. Again, this is a 455 in a 72 Cutlass.
As far as the 68 install, my passenger side is close to the A arm but not a problem. Anyways, they still wont rust like my old ones and will do until I can replace them with some good ones.
They fit the SBO's very well including in the 64-67 frames! Yes I said that correct. So finally a solution to the 64-67 SBO header problems. Sad they have to be chinese knockoffs instead of the big guys making headers for them. A racer I talked to runs them on his 67 with a 330 and said only required a small dimple on a one tube each side, a rob mc mini starter and to open up the end holes in the flange outward as they are abit close together. I'll be picking up a set for the 66.
I just purchased a set of these http://www.ebay.com/itm/262786905684
Damn that's cheap and shipping to Canada is $28. Unreal. They are probably the same China made headers. There's another thread on here about these. They are a copy of the Hooker 3902.
These headers are supposed to fit 65-67 big blocks and 68-75 big or small.
The 65-67 have a tight engine bay. The crossmember is higher and closer to the engine. I wouldn't be surprised if you could swap out the engine mounts on a 65-67 small block for 68-75 mounts which will raise the engine an inch and possibly make the headers fit. I will post a review when I receive them.
RocketV8
Jan 4, 2016 01:45 AM
