Distributor Hold Down Bolt
Old Jun 22, 2016 | 09:49 PM
77ricbaez's Avatar
Yep it's all the way back there, I can see it, sorta...
I don't have that special tool for the distributor nut and I do not want to buy one. What is another way to get at the bolt? I was thinking that I could probably fit a small ratchet and socket in there but what size is the bolt? 1/2"? 9/16"?
Help is appreciated, thanks
Old Jun 22, 2016 | 09:57 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Use a 1/4 drive ratchet and either two 3" extensions or 6" extension. The bolt is 3/8" with a 9/16" head.
VI Cutty's Avatar
Try a 9/16"
Old Jun 23, 2016 | 05:39 AM
76olds's Avatar
Hookers under Hood
I used a 9/16 wrench, open end fixed opposite end that can flex.
Old Jun 23, 2016 | 05:44 AM
For $11 you can have the proper tool or you can learn new cuss words and spend an excessive amount of time and effort trying to tighten 1 bolt.
https://www.amazon.com/Performance-T...ributor+wrench
Old Jun 23, 2016 | 06:21 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Harbor Freight probably has one for 5 bucks.
Old Jun 23, 2016 | 07:18 AM
70cutty's Avatar
Beer Connoisseur
9/16" socket with a universal joint and extension (or 2) works just fine for me.
oddball's Avatar
The dog-leg wrench is practically required for Chevy, but I've never used one on an Olds. HEI makes it a little tight but not bad.
Just 9/16" socket. Small cap dizzy I just use 1/2" drive and a long extension. With HEI use a short socket and a wobble. Assuming it's a normal 3/8" bolt. You never know what folks dig up to shove into a hole sometimes.
Old Jun 23, 2016 | 08:21 AM
CRUZN 66's Avatar
Olds Fever
Short 9/16 flex socket & extension works best for me... You can also use a short socket with a universal flex, as previously stated, but the shorter you keep the socket setup the better...
Old Jun 23, 2016 | 10:49 AM
Cutty77's Avatar
Exactly what I use on my 77. I have the Chevy wrenches and they don't work as well.
Old Jun 23, 2016 | 11:13 AM
redoldsman's Avatar
You could probably use a 9/16 crows foot.
Old Jun 23, 2016 | 12:39 PM
Wow, am I the only person who uses a regular 9/16 combination wrench for this?
Old Jun 23, 2016 | 01:19 PM
redoldsman's Avatar
It has been too long since I actually needed to adjust the timing on my 72 Cutlass. That might be because it hasn't been on the highway for about 10 years. It does have an HEI which is a lot bigger. On my 54 I use a 9/16 socket on a long extension. I have one of the cheap distributor wrenches but it won't work on the 54. Use what works for you.
Old Jun 23, 2016 | 01:43 PM
77ricbaez's Avatar
Also I hate that the vacuum advance hose is so hard to get XD. The darn thing is right up on the firewall... *sigh* GM engineering at its finest.
Old Jun 23, 2016 | 01:48 PM
BlackGold's Avatar
If you know what you're doing (or just think about it real hard) you can re-clock the distributor base to give you more room for the vacuum advance unit. But if you do it wrong you'll totally hose which cylinder fires when.
Old Jun 23, 2016 | 01:51 PM
The position of the distributor can be changed by moving all the wires over one spot either way and then retime the engine.
Old Jun 23, 2016 | 06:08 PM
RetroRanger's Avatar
72 Olds CS
nope ,me too but i just looked at it again today and it is a clear shot for a socket and extension so from here on in you may be the only one.
Old Jun 23, 2016 | 09:14 PM
I never had a problem using a regular 9/16" socket on a long extension.
Old Jun 24, 2016 | 07:34 AM
wr1970's Avatar
Nope i use one and have had no problem. No need to change what works.
Old Jun 24, 2016 | 08:04 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
eggxactly. thats what Id do. its been a while, but how tight is it? I had done some points->Large HEI conversions and dont recall it being all THAT bad....
Old Jun 25, 2016 | 07:35 AM
ELY442's Avatar
Originally Posted by mdchanic
i never had a problem using a regular 9/16" socket on a long extension.
- eric
x2
Old Jun 25, 2016 | 09:25 AM
I never had a problem using the proper distributor wrench either.
Old Jun 27, 2016 | 02:28 PM
76olds's Avatar
Hookers under Hood
Have you loosened the hold down bolt yet? Would the distributor rotate ? The Olds distributors always seem to almost seize in place over the years, can be a bugger to turn sometimes.
Old Jun 27, 2016 | 07:34 PM
77ricbaez's Avatar
I didn't need to adjust my timing so I was spared of that trouble.
FIRST 442
Jul 1, 2018 06:59 AM
serta1
Nov 28, 2015 08:39 PM
shinewill
Sep 17, 2011 05:25 AM
78cutlass
Jul 17, 2009 04:43 AM
mcutlass1969
Mar 9, 2009 08:54 PM
