Dipstick removal
Its press fit int the block, mine came out fairly easily with a bit of coaxing. If yours is tight you might want to try a little bit of localized heat on the block, and a pliers, that wont crush the tube(curved jaw).
If you have the block completely torn down, you should be able to tap it out from the bottom. To answer the more general question, the only method I've found to reliably get the tube out without damage is to use a slide hammer. I fabricated a piece that screws into the end of my slide hammer and just fits into the upper end of the tube. I clamp it in place with a vice grip pliers on the outside of the tube and use the slide hammer to extract the tube. 100% success to date with no damage.
dantecl
October 27th, 2013 02:50 PM
