dauntless 225 v6 oil pan
Old Apr 17, 2025 | 12:17 PM
mickie08's Avatar
Anyone know where to get a repop? I do not ideally want to count on a used ebay one.
Old Apr 17, 2025 | 04:25 PM
BillK's Avatar
https://shipwrecksalvage.net/inboard...an-p-6479.html
Old Apr 17, 2025 | 05:35 PM
Sugar Bear's Avatar
https://www.ebay.com/itm/15399960742...waAnXLEALw_wcB
Old Apr 20, 2025 | 11:08 PM
mickie08's Avatar
so that fits as is, I do not have to change anything in the oil pan, etc.
Old Apr 21, 2025 | 06:29 AM
Sugar Bear's Avatar
mickie08, I don't know if anything needs to be changed. I could only rely on the info the seller fitment provides. Look up the pan gasket, the oil pump pickup on a parts site to see if they are same and view the picture of the pan to see if it will clear the frame rails.
Please let us know what you find.
Old Apr 21, 2025 | 07:10 AM
BillK's Avatar
Exactly which vehicle are you working on ?
Old Apr 21, 2025 | 07:39 AM
BillK's Avatar
Melling does not show a screen for the 225, only for the 231 which tells me something is different. Also appears that there are several different depth pans. That would probably meant the dipsticks are different too ?
I think if I didnt want to change screens etc I would see if I could find a decent used pan. What exactly is wrong with yoours ?
Old Apr 21, 2025 | 04:46 PM
mickie08's Avatar
It is leaking and is pretty beat up. Once I take it off I can determine if it is salvaegable but Id prefer to but have anew one on hand. I think ill go ahead and see about just keeping it. Going ot be a PIA to get it out as I have to lioft the engine but worse case, I will try to clean it up and throw on a new gasket and some RTV for insurance.
Old Apr 21, 2025 | 05:04 PM
BillK's Avatar
It is leaking and is pretty beat up. Once I take it off I can determine if it is salvageable but Id prefer to but have anew one on hand. I think ill go ahead and see about just keeping it. Going ot be a PIA to get it out as I have to lift the engine but worse case, I will try to clean it up and throw on a new gasket and some RTV for insurance.
Be careful with the rtv. It makes matters worse more often than not. Most important is getting the pan rails straight and then not over tightening the bolts. Cork gaskets work remarkably well when installed properly.
norat
Apr 10, 2022 02:07 PM
oldsman71-69
Jun 14, 2015 07:44 PM
badf85
Feb 26, 2015 07:39 AM
dnmfranco
Oct 31, 2013 12:40 PM
815Cutlass1972
May 13, 2010 11:43 AM
