Cutty Stumbling.
Cutty Stumbling.
I recently installed a new carb in my 67 Cutlass and now have issues. After driving 2 miles in 104 degree weather mind you I get home and turn it off only to feel it shut off and stumble like it wants to start again right away. Can this be a timing/fuel issue? In addition white smoke was billowing out of carb itself. I checked coolant levels, no white smoke out of tail pipe, and oil is clear not foamy. Any advice would help me eliminate issue.
It sound like a little bit of deiseling which can be caused by a to high idle, engine is running lean or high timing can cause it and probably the engine is rather hot because it takes quite a bit of cylinder heat to ignite the fuel charge with no ignition fire. If this all started with a carb change I'd be leaning toward the idle being high and a lean condition that can cause the cylinder temps to go up. Hopefully you have the old carb yet as you might need the the the jets and or metering rods.
84oldsDelta88
July 16th, 2012 07:06 PM
